That's an awesome John Deere, albeit a bit rough, I'm still looking for one. Generally the few I do are are always near mint.For now I decided to put it together as it is and keep it in the display. If I can find a good source for those seals I will acquire a few and get this saw back into working order. For now, it looks pretty good. We pulled that John Deere label off the damaged AF cover and put it on this one that came off the saw that donated the piston and cylinder for this project.
I did practice restoring the faded plastic from the damaged AF cover that came off the saw. Amazing what a little time with a heat gun will do.
Mark
I was about to ask how you improved the AF cover. That came out pretty nice!For now I decided to put it together as it is and keep it in the display. If I can find a good source for those seals I will acquire a few and get this saw back into working order. For now, it looks pretty good. We pulled that John Deere label off the damaged AF cover and put it on this one that came off the saw that donated the piston and cylinder for this project.
Mark
I would like to find a spline type clutch drum, or a new of very good .325-8T spur drum to finish this one off. Starts, runs, idles, oils perfectly.
Mark
Seals for the John Deere Super XLFor now I decided to put it together as it is and keep it in the display. If I can find a good source for those seals I will acquire a few and get this saw back into working order. For now, it looks pretty good. We pulled that John Deere label off the damaged AF cover and put it on this one that came off the saw that donated the piston and cylinder for this project.
Mark
That is sweet! I’m so frickin old, I remember seeing them on the shelves at the local Deere dealer. I had a red version from the Homelite dealer 5 miles away. This was before the “One of Each” sickness enveloped me…"58308" seals from LRB arrived this week. They are really 5/8x15/16 like 0609318TC that Tim noted but I was able to get the one installed on the PTO side relatively easily.
I used a screwdriver with a small notch to get under the lip and hook the metal body, then a tap with the hammer to pop it out.
It took a little work to get the lip over the step in the crankshaft, but I was able to get it on without popping off the spring. It also took a little effort to get the body of the seal pressed into the bore but some careful persuasion with a hammer and a deep socket the seal went in.
This is the old seal, as you can see it is a tight spot to work in down in the crankcase.
I also received the spark plug cover this week so that saw is now finished and ready for the display. It starts, runs, idles, oils, in short it does everything it is supposed to to.
Mark
Some of the Homelites have that crankshaft step near the case make it a pain to get the seal over the step."58308" seals from LRB arrived this week. They are really 5/8x15/16 like 0609318TC that Tim noted but I was able to get the one installed on the PTO side relatively easily.
Mark
Headed your way Bill.Ok....done
I scooped this old fellar up recently along with a few other saws. Not sure when I'll get to it, but at least it's here when I'm ready. It's missing a few parts, so I'll start collecting in the meantime.
I'm pretty stoked about finding it. The P/C look great through the exhaust as well. I'm in the middle of another old saw right now though, so not sure when I'll get to it. It's missing the A/F cover, the muffler cover and the back shroud. I'll start gathering parts for it now though. I also got a Mac Super 44A, and a Pioneer P42 as part of this deal. It was a good day!That model has a lot of power. The most of any in that frame.
Looks great, I gotta find a husher muffler.I bought this in the UK last year and Sugar Creek quickly made the decals for it. Husher muffler and auto oiler only. Manual oiler hole isn't threaded and neither is the oil line at the bottom. Made from about 1967-1970ish in Canada by Terry Industries, and this model was made for export to Europe.
