- 5:35 AM
- Mar 13, 2022
- Interior Alaska
Hahahhahaha. The farts dont care about exauhst clamps!They’re engine fart tubes
They’re fine
They’re fine
There’s a few of those around here.I want to build a v8 runna into a crawler someday.
Looks overdue for a fuel filter changeGave the Silverado some attention today. A bit past due but gave it an oil and filter change. Also redid the wooden rear bumper since my first one busted off after swinging the rear end of the truck into a snowbank, went with much thicker lumber this time around. Also zip tied in my lower left headlight better.View attachment 484621View attachment 484622View attachment 484623
Looking good.Got the center seat/console, doors and fenders swapped over. Plus, because I'm still an adolescent I just had to thrash the donor truck through the snow at a high rate of speed.
View attachment 485751View attachment 485752View attachment 485753View attachment 485754View attachment 485755
Swapped the drivers door opening seal, passenger wiper arm also.
I figure this summer I'll booger in some rockers and cab corners and hose the hole thing flat black. Or olive drab..
If you are taking votes, I vote olive drab or fde!Got the center seat/console, doors and fenders swapped over. Plus, because I'm still an adolescent I just had to thrash the donor truck through the snow at a high rate of speed.
Never heard of that, which head casting does it have?6.2 coming out of the Yukon.
Interesting t find it has cathedral port heads. That was uncommon. No biggie as it will probably get aftermarket ones anyway.
Got it loaded up to go to the junkyard. My now showroom fresh plow truck has been renamed the Z-bra by my wife...
I know a lot for people like the ported cathedral ports over the large rectangle port, the cnc ported ones flow as much as the stock gm rec ports with a smaller overall port, better drivability I hear6.2 coming out of the Yukon.
I'll make a decision once I get it apart and see what it all needs. If the crank needs to be turned it will most likely just get a new one..with a longer stroke..I know a lot for people like the ported cathedral ports over the large rectangle port, the cnc ported ones flow as much as the stock gm rec ports with a smaller overall port, better drivability I hear
