redline4
I'm huge in Japan
- 10:32 PM
- Mar 12, 2018
- Rosholt Wisconsin
Wow! This project fights you every step of the way.
It is.
Anybody got any familiarity with the vortec 350/4l80e?
Holy sht, smoothest/quietest V8 I've ever heard. Ran some iso heat, and fuel cleaner in the gas. She touched right off.Yes.
Didn't those have the fixed distributor with the cross-fire cap? I had a vortec 4.3 that vintage and it ate caps, rotors and fuel pumps. Intake gaskets on that one too!Don't be surprised if the intake gaskets give up and leak coolant.
If they do, don't get too upset because even in the van body they aren't all that bad to replace.
They don't make enough power or pull enough weight to tear up the 4l80, so normal fluid, filter changes should be all that requires.
If you do pull the dog house, check the cap and rotor. The distributor used a small mesh screen under the rotor to vent it. They would plug and cause the cap and rotor terminals to corrode. Just remove it with a pick. Think of the small screen in a saw carb. Almost identical.
Hahahaha, are u sure?Jealous! I want a man van
Yeah my brother has one too, meh on the AWD. Need low rage.There's a regular old AWD model a few miles down the road that's for sale. Judging by the condition, as you drive by, I'm guessing bad things happened with it and inside it.
Standard mechanic inspection/Shake down run:
A mining exploration company ran a dozer up buck mountain this summer. Used to be rough, boulder-strewn and bad washouts. ATV only. I tried smashing the van up there. Chicked out 1/4 mile from the summit. Lost momentum on a steep section and the van starting sliding down the hill backwards! If I had chains, wouldve been no problem. Got turned around, and aired the tires down. Crawled my way back down in drive-1 4 low. Couldn't get any momentum or I'd slide like a tobogan.
What i found wrong so far:
1. Wrong shocks up front, too long. Bottoming out against the shocks and not even touching the bump stops.
All that bouncing n jouncing up the mountain knocked loose some crud from the lifter valley. Thing sat for 7 years with sht oil. Could hear a lifter tick when i got home. Ran some fresh oil, tick didnt go away: sticky lifter. Looked over at my 7.3 powerstroke bench and grabbed a 16 oz bottle of hotshots stiction treatment. No fkn joke: tick went away in bout 2 minutes. Whatever was sticky in the valvetrain was cleaned out!
Front leaf springs are too mushy, needs an add-a-leaf. Springs measured 42" long x 3 inch. Weird spring. Something 3" wide x 25 " long add-a-leaf will be hard to find.
Tranmission was a quart low on fluid. Weird torx drain bolt is stripped out. So will just get a new pan with normal drain bolt.
On the climb, kept er between 3000-4000 rpms the entire climb, drive 2, 4wd-high range. The exauhst manifolds were glowing orange.
Couple sections i floored it to redline. Fkn motor had pull up top. An 80 series landcruiser, falls flat on its face at anything above 3500 rpms. Not sure what the cam specs are be she pulls hard off idle, and caries some fkn punch all the way past 5000 rpms. Very broad/linear power delivery. Torque convertor was right on the money. Would start moving the van up hill, just above idle.
Vortec 350 got plenty of power to move all that heavy 1 ton drivetrain. Does need truetracs front n rear though.
kcturbos.com
bankspower.com
