Grease Monkey Garage
redline4
I'm huge in Japan
8:30 PM
Rosholt Wisconsin
Oh boy! Wet timing belts! Brightest idea ever. They are going great for Ford too!
Timing components at the rear of the engine that are inaccessible with the engine in the truck is probably the most genius of it all.
But if we are going down the rabbit hole,
Iron block LS for best engine ever
redline4
I'm huge in Japan
8:30 PM
Rosholt Wisconsin
I figured, or found out a few things on my car.
First thing is my Corvette style filter/regulator isn't regulating..
My fuel pressure at the rail is 100psi.
Another thing, Holley calls their tune files global configuration file, or GCF.
If I use the little 3.5" handheld touchscreen and wizard to build a base tune, it works, allows me to do the required tps reset but is much more basic.
If I use a GCF from the terminator x software off my laptop, there's much more I can do, but it fails the tps autoset every time.
So I used the handheld to create a baseline, then connected my laptop to modify it.
When I changed the actual fuel psi parameter from the 60psi baseline to 100, it still ran like garbage, but less garbage..
At this point I've pretty much decided I am going to pull the fuel tank, strip out all the lines and re-plumb the whole thing with AN lines and an adjustable regulator in the return.
While it's out, I will also need to cut the filler neck and extend it with a few inches of hose. Due to the pump, I had to shim the front of the tank and it puts the filler at a real pain in the aśş angle at the back bumper.
Canadian farm boy
“Normal” people scare me.
9:30 PM
Ontario, Canada
I feel your frustration with the fuel pressure regulator. I’ve tried 3 corvette style regulators. 2 cheap pos and 1 actual ac delco and none of them would keep my fuel pressure close to 60psi. Only thing I can figure is that my fuel pump just over powers them. I’m running a walbro 255lph in tank pump. My next step is basically the same as yours. I’m going to install a basic inline fuel filter and an adjustable pressure regulator under the hood. IMG_6076.jpegIMG_6077.jpeg
mainer_in_ak
5:30 PM
Interior Alaska
Overpriced, Warn, not so premium hubs: entire things are made of aluminum.
Mile marker: stainless steel bezels cromoly hub:
jacob j.
Only the weird
6:30 PM
Coastal Oregon
I have Mile Marker hubs on my Pathfinder. They're well-built units and function well, but after a couple of years the chrome is peeling off the bezel.
redline4
I'm huge in Japan
8:30 PM
Rosholt Wisconsin
I feel your frustration with the fuel pressure regulator. I’ve tried 3 corvette style regulators. 2 cheap pos and 1 actual ac delco and none of them would keep my fuel pressure close to 60psi. Only thing I can figure is that my fuel pump just over powers them. I’m running a walbro 255lph in tank pump. My next step is basically the same as yours. I’m going to install a basic inline fuel filter and an adjustable pressure regulator under the hood. View attachment 458745View attachment 458746
I ordered the Lowdollar pressure sensor too.
I heard a few guys saying they had some accuracy issues, but they were all turbo or supercharged applications with high HP. A few psi can make problems for them I'd imagine.
mainer_in_ak
5:30 PM
Interior Alaska
3 year old warn. Not impressed.
Had a Warn china drill winch that broke at the Chuck. Where it snapped, the grain Looked just like that cast pot metal.
Warn is like my Dewalt tools: everybody knows the name and the sht is overpriced.
Pulled coupla dead Warns off my 2 yamayeahhahas. Piss poor waterproofing of internals. I live on a river, so that warn-walmart stuff ain't cutting it.
Mile markered that sht:
davidwyby
Rural desert logging
6:30 PM
Extreme Southeast CA
Thinking about a U-Haul 8.1 for the shop.
redline4
I'm huge in Japan
8:30 PM
Rosholt Wisconsin
I had one in an 02 GMC with the 5 speed Allison.
Great engines. Crank sensor can be a legit pain if it fails and is seized to the block but that's about it. More torque than the 6.0's. I thought it was a shame when they went away.
davidwyby
6:30 PM
Diesels have become overregulated, overrated, over complicated, overly expensive…
mainer_in_ak
5:30 PM
Interior Alaska
I'll never forget my first diesel injector job on a 6bt. Was $375 for new bosch 6 injectors. All accessible from the side of block. Fresh injectors she hit 22 mpgs at 60, still grinning.
Can't even get a fkn 4 barrel carb for that price.
On the 7.3 powerstroke, rosewood wants $600-$700 to rebuild my heui injectors.
mainer_in_ak
5:30 PM
Interior Alaska
330,000 miles sienna . Misfire on cylinder number 1. Compression good. Since tranverse and against the firewall, will run 3 new coils on the firewall bank, new plugs whole way round, and replace cylinder 1 injector.
Always weird going from working truck diesels to carby mercan iron to chainsaws, atvs, snowmobiles to a Japanese road warrior.
