Grease Monkey Garage
cuinrearview
Handy dood
10:50 PM
Dowling, MI
davidwyby
Rural desert logging
7:50 PM
Extreme Southeast CA
Nope, as is with 60s. The oiing system in the v8s in those was sub-par, but a 429 or 460 solved that. The transmissions were all good, and the 205 case was one of the best. Hell, even the 300 six was far ahead of what competitors were putting in base model trucks.
It’s got a closed knuckle 44 in the front
Duce
10:50 PM
Roscommon, MI
It’s back in, can make it turn over by jumping fuse box. Starter and run relays have no power, rest of box is powered. Immobilizer has become a problem. Thanks again for your help.
Woodslasher
Teh debil
7:50 PM
Commiefornia
Dodge chit is getting old, took her out for a street run yesterday and ac didn't work in 100 degree heat, alternator chit the bed, and when I went to replace the fuel filter tonight I noticed cracks in the exhaust manifold. Oh yeah, and the alternator I got today was wrong. Turns out the SLT trim packaged trucks use a different alt connector style! :BangHead:
Woodslasher
Teh debil
7:50 PM
Commiefornia
Took the Dodge over to my grandma's place to bring home a trailer load of oak and I just finished backing up to a trailer when "PSHHHHHHHH!!!!" Ac line went boom. So, I'll be picking up a new one tomorrow and recharging the system..... again.
Woodslasher
Teh debil
7:50 PM
Commiefornia
@redline4 or any gearhead, is grease leaking out of a new (~500 miles on it) timken hub unit normal or cause for concern? I redid almost all the front end parts (steering, brakes, bearings, etc) on my Dodge about 500 miles ago but when I pulled it all apart again to replace the drivers side diff seal I noticed there was a fair amount of grease coming out of the seals on one of the hub bearings. Should I replace it again or is some seepage normal?
redline4
I'm huge in Japan
9:50 PM
Rosholt Wisconsin
Got a pic?
I'd think some seepage would probably be ok and considered normal.
Woodslasher
Teh debil
7:50 PM
Commiefornia
Got a pic?
I do have a pic, but I replaced the bearing anyways and now my front end shudder seems to have gone away so I'm guessing it was no bueno. Fyi, all that grease came from the hub within the last 500 miles, none of it was pre-existing, from other sources, etc, and there was even more stuck to the hub unit.
redline4
I'm huge in Japan
9:50 PM
Rosholt Wisconsin
That looks like more than what should be on there in my opinion.
Duce
10:50 PM
Roscommon, MI
Ok, I am trying to lay low on helping people with their cars, but granddaughter has a 2012 chevy malibu with sporadic starting issue. Replaced fuel pump (what a joy, body still hurts for wiggling around on garage floor, drop tank, no access port) still does it. If you pull pump relay (replaced that also) and plug back in, it may start (think that is just a coincidence). Car will start and run fine most of time, sometimes cranks but will not start, let it sit, or pull relay, push back in, car starts. Car shows no engine codes. Any ideas before it's off to dealership? Wife says I am too old for this! @redline4
redline4
I'm huge in Japan
9:50 PM
Rosholt Wisconsin
If you can get it to not start, check for voltage at the connector in front of the fuel tank between the large Guage gray wire and the ground, black wire next to it. I can get you the connector end view if you want it.
I have seen that connector have poor terminal contact causing intermittent no start (no fuel pressure) as well.
Duce
10:50 PM
Roscommon, MI
Thanks, will do that, if she leaves her car here long enough. My wife, daughter and granddaughter would put roadrunner to shame!
