Grease Monkey Garage
Sagebrush33
4:14 AM
Upstater
Just a quick one. Is the hyd dump pump trans driven? Could it be transferring into the hyd tank for body? Surely if it was in radiator cooler it would be shoving out overflow bottle right?
It is an electric over hydraulic. Good thinking though. I would think, from the 6-7qrts during our move up here, and the 6 i just dumped in today would raise the level past the full mark LOL
Canadian farm boy
“Normal” people scare me.
4:14 AM
Ontario, Canada
Finally got my LS swap close to done. Took my car over to a guy to have it tuned. Guy calls me a few hours later and says he got it close to done but my oil pressure went for $hit. It was at 25psi cold and 10psi hot. No bueno. I hooked up a mechanical gauge and verified it was in fact way lower then it should be. The engine was still running good and wasn’t making any unusual noises. After some thought I concluded that either the pressure relief valve in the oil pump was stuck or the o ring on the pick up tube going into the pump was the wrong one. Long story short I tore the front cover off and dropped the oil pan down and replaced the oil pump and the questionable o ring plus since I can’t leave anything stock I ported the new oil pump and shimmed the pressure relief spring while I was at it. Now at idle I have 60 psi oil pressure cold and 45 psi hot. 2CC13821-73B5-49AB-B36B-8B06CE175D3C.jpeg93E1B0D5-C0FC-44C2-BD08-0CFB4B3A7C94.jpegD0DF6B6E-D955-474C-8C6A-E8620DE5447C.jpeg1F251795-C288-470A-8533-3C601D6CB729.jpeg94DA3276-0D97-4713-967A-2D4707BE225F.jpeg
Sagebrush33
4:14 AM
Upstater
Have a question that I'm hoping one of ya could help me with. I've been looking at a lot of new used trucks. I want to put myself behind a Cummins again. Miss my ole 12v. Looking at a '15 with low miles. G56 manual, with an aftermarket twin disc ceramic clutch. How stiff will this sucker be to be a DD?
Steve
Excellence!
3:14 AM
Stay as far away from the DD clutch as you can. The two that I have messed with have had nothing but problems. Pedal is slightly more heavy than a stock clutch. Both the clutches I messed with where south bends. Both had the rubber isolators for the center iron disc break apart and then it rattles terribly anytime the clutch is disengaged. Put new isolators in and they bother ate them in a few thousand miles. Convinced the owners they don't need the bragging rights of a DD clutch and put one back to a single puck and the other stock. Both have close to 100k on them no problems now.
The only problems with the g56 is the throw out bearing quill is stamped steel. Upgrade to a billet or cast quill and you will be happy you did.
Sagebrush33
4:14 AM
Upstater
Good to know. I'm in lust with the rest of the truck though. i'll have to keep in mind to replace the clutch, and flywheel if i wait to long.
Sagebrush33
4:14 AM
Upstater
Oh and this clutch is made by Cutch Masters and a billet version. That's all the info i got on that tidbit.
Steve
Excellence!
3:14 AM
Most people have no idea how or budget to build a reliable Cummins to produce the torque to require a DD clutch. Most put them in to add a few inches to their dick.
Steve
Excellence!
3:14 AM
The switching reservoir is a different bolt pattern than the single one. This is an 88 truck built on a 95 frame so it is not drilled for the reservoir. Made a template out of 1/8" ply to drill the hole without a bunch of measuring under the truck.
PXL_20220807_114328167.jpg PXL_20220807_120706412.jpg PXL_20220807_120718269.jpg PXL_20220807_120957293.jpg PXL_20220807_121351043.jpg
Sagebrush33
4:14 AM
Upstater
Sagebrush33
4:14 AM
Upstater
