- 5:46 AM
- Feb 19, 2021
- Upstater
i sold the suburban i had
It is an electric over hydraulic. Good thinking though. I would think, from the 6-7qrts during our move up here, and the 6 i just dumped in today would raise the level past the full mark LOLJust a quick one. Is the hyd dump pump trans driven? Could it be transferring into the hyd tank for body? Surely if it was in radiator cooler it would be shoving out overflow bottle right?
Have a question that I'm hoping one of ya could help me with. I've been looking at a lot of new used trucks. I want to put myself behind a Cummins again. Miss my ole 12v. Looking at a '15 with low miles. G56 manual, with an aftermarket twin disc ceramic clutch. How stiff will this sucker be to be a DD?
Good to know. I'm in lust with the rest of the truck though. i'll have to keep in mind to replace the clutch, and flywheel if i wait to long.Stay as far away from the DD clutch as you can. The two that I have messed with have had nothing but problems. Pedal is slightly more heavy than a stock clutch. Both the clutches I messed with where south bends. Both had the rubber isolators for the center iron disc break apart and then it rattles terribly anytime the clutch is disengaged. Put new isolators in and they bother ate them in a few thousand miles. Convinced the owners they don't need the bragging rights of a DD clutch and put one back to a single puck and the other stock. Both have close to 100k on them no problems now.
The only problems with the g56 is the throw out bearing quill is stamped steel. Upgrade to a billet or cast quill and you will be happy you did.
Looks like you're getting the hang of it now.
Nice job! glad to see you're going to add in a H pipe. I like a balanced exhaust.
As always Steve, nice work!Started a project last night. Going back to dual tanks. Carrying only 19 gallons on a 14 mpg truck is less range than an electric vehicle. This is America, we can't have that!
View attachment 345325 View attachment 345326 View attachment 345327 View attachment 345328 View attachment 345329
