merc_man
merc_man
- 9:14 AM
- Feb 24, 2016
- southern ontario
I tried filing the flywheel key to advance timing. Tried saw and seemed to be stronger.
When you guys are getting ready to port a saw. Do you bother checking port opening degree and stuff or wait till you deck or gasket delete to check?No.
Exhaust roof does three things. It determines when compression of charge begins, it determines the amount of trapped volume, and it determines when combustion pressure is vented.
There are some general rules on this. In my mind you want it to open at the very point where pressure from combustion becomes close to parasitic drag losses. That's the theory at least. The actual amount that's best for any individual saw varies because of design and stroke.
A lot of guys use a rule of thumb of exhaust opening based on displacement for a worksaw. 105 on 50cc, 103 on 60cc, 101 on anything larger. But no one fits all in this game. If you have too much compression, somethings you want a higher roof. If you want more rpm and less lugging power, sometimes you want a higher roof. Etc...
The more you learn in this game, the more confusing it becomes. I hope the above helps.
I always degree them first if the model is known to have slight variances, like an 044 or 066, or if it's new to meWhen you guys are getting ready to port a saw. Do you bother checking port opening degree and stuff or wait till you deck or gasket delete to check?
are the cylinders all a bit different on 066?A 066 is a very random saw indeed.
Sounds like it could be confusing.They are all over with timing.
I used to on all. Still do on some.When you guys are getting ready to port a saw. Do you bother checking port opening degree and stuff or wait till you deck or gasket delete to check?
Very cool. What are you using for grinding?
Wow, a personal greeting from the Master. You do good work sir, and thanks for sharing!Hello, and welcome to OPE forum.
A lot of them don't go below the bottom of the exhaust port or transfer ports. Some shops were grinding the piston down at the transfers and exhaust to change the timing. I always wanted to try it to see how it would do since flow would be different there instead of hitting a straight edge like the transfers do.
