- 3:33 PM
- Dec 31, 2015
- East Jordan, MI
3/8 lo pro nk = light Saber on my 026. Smoother too
It would be if you could get some more rpm out of that girl. Nice builds fellas!The only other echo bar I have is a 14" in picco.
I'm wondering if an 8 pin on this saw and a 14 would be a light saber.
First things that come to mind is a v stack with a good flowing filter and an unrestricted carbI have quite a few idea's to try.. from ignition, to carbs even air filters... it is going to get interesting for sure.
12-14 hours a day watching a mill go back and fourth I have lots of time for brain storming, forgot my notepad the first couple days.
Any specs?i looked on the echo global site and the give the hp rating of 2.91 of the cs 490 they have came out with a updated version of the cs 500p and it has boosted hp ratings from 2.91hp to 3.50hp. the 490 and 500p has the same hp.
here is the new cs 501 with a sexy bar on it 3.5 hp and comes with a decomp valve.
Yes, yes, and I think I'm gonna try a big carb. Like 372 bigalong with some modified small carbs. Start small and work my way up until I don't notice any gains.
Make a v stack and try a more stock appearing a/f setup.
Also plan on adjusting the timing. Advanced and retard. Just to see.
Joe,Yes, yes, and I think I'm gonna try a big carb. Like 372 bigalong with some modified small carbs. Start small and work my way up until I don't notice any gains.
I agree with Mdavlee. On your squish did you cut it flat or angle it?That may help some. That's a small area to flow through
Exactly what I was thinkin, chit can that carb before you do any more port workMatching everything @ BDC will gain some due to the lighter reciprocating weight and better aerodynamics in the case at high rpm
I'd be guessing about that exhaust, it seemed a little low to me when you guys first started this thread, so I decided to pull up a chair and see what happened.
I agree on the carb limiting you guys, and would look to alleviate that roadblock first, then decide what to do to the ports after. You could be chasing your tail untill that carb runs clean
Angle. But not a matching arc.I agree with Mdavlee. On your squish did you cut it flat or angle it?
Joe,
I'm not a carb pro. Not even fair to say I'm a novice.
Maybe @Terry Syd can give us a hand?
In my limited experience, I've found that carbs that are too small are tough to lean out and ones that are too large can't be richened.
I've also seen, first hand, that opening a muffler has caused a saw to need the H needle turned in and not out as one would expect.
I think a stronger vacuum just pulls more fuel out of the nozzle. I've seen Terry Syd's posts where he closes off one H jet and opens the adjustable one.
If we can find a larger Venturi carb, that would be great. I think enlarging the Venturi on this one enough may drop the vacuum signal on its own. I am going to try this first, like Carl did.
I saw 13,550 with no air filter. It was over 13,500. I didn't want to piss rev or lean it too much as it was its maiden voyage.
I broke my intake boot retainer spring. I had to use a traditional 044 clamp on mine.
There's no video, because I ran out of time and daylight, but I had the 20" bar buried in oak and the saw was actually quite good with it.
I'm hoping to get some more footage next Saturday. I'll make an oak block and try to set myself up to do a few before and after shots in the same piece of wood.
Timing can really limit rpm.
Randy says that any timing advance didn't work on the 500p. This saw is basically it's twin mechanically.
