Echo cs 490 porting
Red97
12:35 PM
MI
Got some grinding in. Got exhaust to 106.5 without extra tricks.
That is looking very nice. Do you use carbide burrs,or stone/diamond coated bits?
What did you got to for width? 65%?
120ish transfers ?
Wondering if you could Check the piston pin diameter vs that 346 piston.
A 44mm husqvarna piston might be a viable option for single ring setup. Just brainstorming out loud.
Anxiously waiting to see what kind of gains you end up with.
12:35 PM
120ish transfers ?
It got late fast last night. I'll get you the pin measurements.
I hope to get it done before day's end.
Did you figure anything out with the carb?
Red97
12:35 PM
MI
I won't be back home till late next week to experiment with my carb ideas. But I have lots of time to think/research, and I will have a few different carbs to play with when I get home.
I think I found the bottleneck in these ports. It may be why the saw runs out of steam. I don't see a lot of flow happening here.
The 346 pin is 10mm in outside diameter Red.
Here's another pic of the tiny 490 ports, this with a penny for perspective.
These are gonna need a few hours of TLC.
Yeh, I seen that, lots of time getting it opened up the way I wanted.
Wonder if the echo uses a 10mm pin? Probably not, they just have to be different lol.
12:35 PM
I see where you're going here. I will check.
So you opened yours?
Red97
12:35 PM
MI
I did.
And looking for a single ring piston too. Would be nice to just cut a flat roof/band.
bikemike
11:35 AM
Cottage grove mn
It is jap so it will be a metric something
Red97
12:35 PM
MI
If the Echo uses the small pin, a 246 piston may be an option, or even a 5000+/jonsered 490. Both are single ring, with a flat top.
Thank you. That opens up some more options.
You ever built one of these small echo's?
bikemike
11:35 AM
Cottage grove mn
Is it timing advanced? Can't remember if I asked that. Both my echos took well to a advanced timing 360t and cs510 360t made a big difference
Red97
12:35 PM
MI
No I haven't, but you all have sure got me thinking about 'em! I ran Matts 500 a while back, and the only thing that impressed me about it was the light weight.
Definitely a light weight, hoping to squeeze out a few more rpm to make a great limbing/small wood saw. What a 50cc should be.
I haven't tried yet. Never even pulled the flywheel. Might try .005 off the key at a time, just for gins and giggles.
When I get back, I am going to adapt the 510 style filter, see if that gains me anything. Then start working on carbs...
echoshawn
Blinker fluid
12:35 PM
Woods of North Idaho
Been told by 2 different builders that it doesn't seem to respond to a timing advance.
It'd be nice to see someone prove that wrong lol
bikemike
11:35 AM
Cottage grove mn
Send me a pic of the back side of your carb lookin into the venturi.
Timing advance is easy cause they have a woodruff key so you can always go back if needed
bikemike
11:35 AM
Cottage grove mn
On the jug of that saw with the narrow transfer ports I'd chuck up a chain file and make it a bit wider. I heard the file in a drill trick not long ago and had to try it on a exhaust flange and it worked vertical well
