Echo cs 490 porting
echoshawn
Blinker fluid
6:11 PM
Woods of North Idaho
This was $160 on CL
Was $130? Iirc at a pawn shop.
Gonna throw a fresh .325 at the 346 and cut a couple cookies with it today.
Not a fair comparison with the 500 running full 3/8, but both have similar compression.
Ran my buddy's EC ported 346 yesterday. Yes it was impressive, but my stock one sure revs up quick.
500 just had that Echo torque I like though
Nutball
5:11 PM
Mt. Juliet, TN
Have you ever noticed this short circuit between the transfers? I'm thinking some JB weld needs to go between the ports to keep their flow separated.
If I knew it was there before hand I would have put epoxy there. In the sink water would leak significantly into the exhaust side transfer from the intake side. I figured it worth a try to plug the gap between the cylinder and caps with epoxy to blend the transition.
TXFitz
Active OPE Member
5:11 PM
N. Texas
I'm new to OPE and recently picked up a CS490 with a scored piston and cylinder but it still has 150 psi and runs great. It will be my first attempt at porting a saw and this thread was most helpful.
