Dumb#@$ Question About Sharpening
deye223
AIR FUEL SPARK VROOOOOM
2:41 AM
A key thing to keep in mind, is that those are recommendations or suggestions for general use.
One of the advantages of sharpening your own chain is that you can use custom angles for your wood, your saw, and the cutting that you do (it's all about you!). For example, 25° is often better for hard or frozen wood. 35° is often preferred for soft wood. If you mostly cut one type of wood, with one saw, you might find out that 27.5° is the best angle for you.
Best way to find out is to start with 3, identical chains and file / grind them to 3 different angles. If you notice a big difference, go that way. If you don't notice a significant difference, stick with the 'standard' angles.
Philbert
Yep here in Australia with our hardwood when it's dry top plate angle for me it's 20 degrees there about does not cut as fast but stays sharp longer more cutting less sharpening .
when I'm lucky enough to get into green red gum or pine top plate angle around 35 degrees and a lot more hook on the side plate this is with semi chisel chain .
4:41 PM
When I use a Granberg type file guide, I find that I have one hand up by the top rod for power, and one down by the file for pressure and guidance. Pushing and pulling depends on which side I am filing. If I think about it too much, it does not work as well!
Philbert
That is the prettiest file guide I have seen to date. :eeeeek:
I have two "blah" ones in that style, haven't used them since I got my first Archer FastFiler jig. :confused:
davidwyby
Rural desert logging
7:41 AM
Extreme Southeast CA
I have a Pferd 2n1. Works pretty good, gives you something to go off of for angle and you can tweak that as desired. Seems like they leave a gullet sometimes after a few sharpenings, so I come along after and freehand those out. Also, for soft wood, I take more off the rakers freehand or with a husky raker guide after....I also use the husky guide on my skip chains as the 2n1 doesn’t fit. Working on getting better at freehand.
I noticed last time I was playing with sharpening that if I rolled the file up and out of the cutter a little as I pushed it across, (kinda like what’s going on in that video) it pushed the burr up and out and was very sharp...but I’m sure that edge is delicate and doesn’t last.
Philbert
Chainsaw Enthusiast
9:41 AM
East Dakota
I've got a Granberg that's probably 20+ years old that I use. Any advantage to this one? Sure looks cute!
No advantage if you are happy with your current one. This one is fairly compact and mostly metal. A good choice if someone is looking for one.
Philbert
sundance
10:41 AM
SW PA
Philbert
Bummer.....I'm not in your league for sharpening items but do like them. Might have to try one out just for the hell of it. Sounds like a decent unit to acquire even if not needed.
Philbert
Chainsaw Enthusiast
9:41 AM
East Dakota
Just sayin, but you push the file instead of drag it.
Odd, but related, thing I ran across on eBay: a grip designed specifically to help you push your file from the front:
Yeah, you could make one just to try. This one is from Tecomec, who makes the good Italian grinders. Not compatible with some file guides, but is only $6, shipped, if anyone is interested.
Philbert
hotajax
10:41 AM
Eastern PA
Is an Italian grinder as good as an Italian hoagie? They don't oven roast the hoagie. I'll bet the freshly made Italian hoagie tastes better than the grinder.
sundance
10:41 AM
SW PA
Started looking...seems Tecomec offers three different units, the MS-1 being the bottom tier.
Now I'm not so sure which one to order.
Philbert
Chainsaw Enthusiast
9:41 AM
East Dakota
Check the ArcherPlus eBay site: he sells all their models I believe.
Philbert
sundance
10:41 AM
SW PA
Philbert
But which to pick? I like the looks of the WS-1 but the better ratings of the other two are enticing.
sundance
10:41 AM
SW PA
Ordered the push grip. Expect I'll order one of the Tecomec file guides in the spring once shipping settles down a bit and I get closer to my cutting season.
Really like my Stihl FG-2 when I have several chains off the saws to do but prefer bar mounted most of the time so I don't pull the chain other than cleaning things up.
Philbert
Chainsaw Enthusiast
9:41 AM
East Dakota
Really like my Stihl FG-2 when I have several chains off the saws to do . . .
Might be hard to compete with an FG-2; you mentioned ‘Granberg’!
There is the FG-3 . . . about the same size and mass as the FG-2
Philbert
