I prefer Remington brand file guides. They have marks in the middle for 22.5 deg which I tend to use on most saws for durability. Stihl square grind seems more like 17.5 I'm guessing. Anyway, try to fing a guide meant for the file size you are using, I ended up filing the groove the file sits in on a Remington guide to hold a 7/32 file, it was originally a 5/32 guide. Because file height relative to the tooth matters: too high, and you get very little hook (can be good for durability, bad for self feeding and speed cutting). Too low in the tooth, and the tooth might not even get sharpened, or it will have too much hook, and be grabby and dull quickly.
