deye223
AIR FUEL SPARK VROOOOOM
- 11:44 PM
- Sep 18, 2018
- Australia
Yep here in Australia with our hardwood when it's dry top plate angle for me it's 20 degrees there about does not cut as fast but stays sharp longer more cutting less sharpening .A key thing to keep in mind, is that those are recommendations or suggestions for general use.
One of the advantages of sharpening your own chain is that you can use custom angles for your wood, your saw, and the cutting that you do (it's all about you!). For example, 25° is often better for hard or frozen wood. 35° is often preferred for soft wood. If you mostly cut one type of wood, with one saw, you might find out that 27.5° is the best angle for you.
Best way to find out is to start with 3, identical chains and file / grind them to 3 different angles. If you notice a big difference, go that way. If you don't notice a significant difference, stick with the 'standard' angles.
Philbert
when I'm lucky enough to get into green red gum or pine top plate angle around 35 degrees and a lot more hook on the side plate this is with semi chisel chain .
