danimal
- 3:38 AM
- Apr 12, 2016
- Armpit of da Midwest
Hey Dub11...is that a modern day scottish claymore in yer avitar?
There is a difference between a rocked chain that forces itself out of the cut (like above), and and dull chain that the operator can dog in.
The saw is not alone it has a person attached to it henceforth it needs to be pushed harder to compensate for the dull chain! That produces more heat period! I know for a fact!Mike, that is an interesting suggestion about the infra red gun.... But I would still contend that its easier for a saw to pull a dull chain... hence the higher rpm.
No *FireTrucking ideaIf you keep running the saw with the chain dull ,I will kick you in the shin for being a *pretty boy.
Why Is DumbA$$ sensored ?
I'd definitely buy that an engine works harder by pulling a sharp chain through wood... hence the bog.
I . . .was shocked by some of the experienced climbers ability to look like they were "filing" but rarely got the chain "sharp" ...it would cut but not what I could produce with a grinder...and I stink.
I think this is probably more common than we'd imagine.
I've seen those before... Still trying to figure out the mechanics of it. Was always skeptical, and now my skepticism is confirmed! LOL!may as well put the chain in the dirt to touch it up
Why?I've seen those before... Still trying to figure out the mechanics of it. Was always skeptical, and now my skepticism is confirmed!
Why?
Tried it?
Bevel sharpens on the top of the cutter. Cuts more aggressively than many other 3/8 low profile chains side-by-side. See photos in the PowerSharp thread.
http://opeforum.com/threads/powersharp-chains.5620/
Philbert
I'll just run some 20-50 it the crankYikes look at the bottom of the con rod.
