- 11:10 PM
- Jan 8, 2016
- Farmington, CT
Disagree. Look at the chips. A sharp chain will cut through the wood fibers; a dull chain will try to tear them, in addition to the friction created by rubbing past the wood with the rounded edges. I think that someone may have already suggested trying this with a kitchen knife to see how much force it takes you to cut through a piece of meat with a sharp and dull knife.
Philbert
No question using a dull instrument requires more effort overall to cut through something, and perhaps you won't cut anything at all if dull enough.
BUT, overall effort and load are 2 different things. The more load is placed on a motor, the more the RPMS drop. ...and vice versa... the more the rpms drop, the more the assumed load. Therefore, a sharp chain cutting through wood will load a saw more than a dull chain doing zero cutting but adding heat to the whole system...
with regards to that 254, yes it got hot.... the question is why
