WI_Hedgehog
- 6:18 PM
- Sep 8, 2023
- Milwaukee, Wisconsin, U.S.A.
Maybe buy that Nice XS 660 to try it on.
I have a bunch of old wheels so may play with dressing one “to fit”A 3/16” file would probably be close.
A narrow grinding wheel with the grinder tipped way over would probably match up to the angles.
Sharpie up the cutter and touch it a little at a time and adjust the grinder or file to hit all the surfaces equally. Might take a couple cutters to get it dialed.
This is a similar grind but durable since the cutter face is more vertical. Lean it for way so the edge is thinner and it gets faster and dulls faster.
That is a ugly looking raker!A 3/16” file would probably be close.
That is an old .404 chain I got somewhere and the rakers were already a mess, tooThat is a ugly looking raker!
No love rounding the front for less shock load to the chain?
Cutter looks durable but slow.
I guess You have to make compromises in the stuff You are cutting.
Kinda makes me glad I mostly buck two species, oak and beech - I tune my chains for oak and it just zips through beech.
Doug is a little confused about side plates cutting. It only cuts the the thickness of the chip according to depth gauge
I betcha get more cleaning out a face cutDoug is a little confused about side plates cutting. It only cuts the the thickness of the chip according to depth gauge
More than what?I betcha get more cleaning out a face cut
More than a few thou at the top.More than what?
I don't understand what you are saying.More than a few thou at the top.
The top plate takes a cut and the side plate severs it and makes a chip, according to the "bite" the depth gauge allows.
Are you implying Doug was correct in saying the side plate "cuts" down as for as he was indicating?
How?
Not sure I want muh cutters playing a left n right tug o war......
Maybe it is a hi tech chip mulching action that turns chips to dust?
LOL
....no offense intended
