Colder weather Bar oil pour test - Kinetix Extreme, VP, & BelRay
Johnmn
5:29 AM
Minnesota
I just talked to them and they will deliver a case to Abilene Ks. Bought 3 cases for $6 a gallon. Gonna try it and if it works I can buy a 55 gal drum for $240. Thanks for posting that!
Happy to help! If I was to start logging again I'll just have a 55 gal drum on hand.
Wolverine
dilligaf
6:29 AM
The Bel Ray oil sure works good for me.
Tim, is there any chance you have or can get the part number to order the Bel-Ray by the case? I asked in a prior post but never got an answer. My old boss at the bike shop could probably order it for me as he stocks Bel-Ray and I really like the apparent tackiness. I can't find those numbers in any of the catalogs.
Moparmyway
Its just a saw
6:29 AM
In a meeting
Here's the second video.
Bottles were sitting outside for 6 hours and was around 4°F when I brought them in.
Added the Amsoil Semi Synthetic to the test this time. Didn't try the Bel-Ray this time around.
Amsoil pours fantastically at those temps, but they’re very proud of that stuff !
sawmikaze
6:29 AM
steeltown
We’ve been running this in the processor and the saws. Unlike the tractor supply bar oil I don’t have to cut it with diesel for winter use. Stihl’s and dolmars will plug the bar oil hole with the tractor supply in 20* weather if it isn’t cut with diesel. The huskys seem to have more oil pressure and don’t care too much what bar oil. Bar oil is one of those things I couldn’t really care less what brand it is, as long as it’s got tacky ness to it. I mean it’s just money your throwing out off the bar literally... the cheaper the better. But I definitely noticed less bar wear with using this stuff, which is nice. Can’t complain about that. View attachment 280058
That's what we have in a 55 gallon drum. Seems fine.
SOS Ridgerider
Muffler Modded Member
6:29 AM
Central CT
This is the back of the jug. Not sure if that’ll help.
3BA58D3A-5EBB-4AD5-AC86-A3BE7030BE9A.jpeg 15770CCA-FD2D-4C3E-B8BB-21F26517B878.jpeg
Cat 525
5:29 AM
Central Kansas
I have trouble finding it also. O'Reilly's is supposed to be able to get it. Do you have any of them around you? I have to check at my local one yet.
Wolverine
dilligaf
6:29 AM
I don't. Closest is over 85mi one way. Thing is, if I can come up w/ a part number, boss will get me stuff at his cost.
Appreciate any info is someone runs across the full case Bel-Ray part number. Another reason I like it because it's made in the USA.
EDIT: Just found a number on their website and will pursue that. 302431150000
Habada
6:29 AM
Greenwich, NY
302431150190 is the part number
Brufab
6:29 AM
michigan
Bel Ray at Menards is like 12.99-14.99 gal in my area I believe. I ended up buying the poulan oil because it's purple and I can see it better on my old manual oiler only saws. The belray was clear.
