Icepick69
Fart knocker extraordinaire.
- 6:54 PM
- Nov 23, 2016
- North Carolina
thay a lot of chain to grind. What machine does he use?
I sell stihl square ground chain, 3/8 and .325 and 3/8 picco if you ever wanna try some, let me knowDamn man looks great!!!!
What brand is your square grinder....I can't imaging barely touching the tie strap like that would hurt anything.....
I have never ran a square ground chain in my life, would love to try one!!!!
Does the edge last as long a regular chisel chain????
Oh man he has ABUNCH..... square, round, many different brands of each....he has the coolest raker grinder I have ever seen....you just crank a handle, the chain spins, and a stone glances each raker.... VERY cool!!!!!!thay a lot of chain to grind. What machine does he use?
Hey thanks for offer.... I may buy some 3/8 off of ya sometime.... atleast it would be easier to learn how hand file-square on a chain with the correct cutter profile already on it!!!!!!I sell stihl square ground chain, 3/8 and .325 and 3/8 picco if you ever wanna try some, let me know
I've heard of a raker grinder like that, but can't find it. Do you know what kind it is or a link to it?Oh man he has ABUNCH..... square, round, many different brands of each....he has the coolest raker grinder I have ever seen....you just crank a handle, the chain spins, and a stone glances each raker.... VERY cool!!!!!!
Thanks
Don't know why you aren't getting any work, Them teeth look great. My problem is, I get very worn chain and takes forever to get rite. I'm thinking about raising my price for rocked and bad worn chain.I've also have not had any luck with grinding chains for $$$. I've got decent equipment round/square/raker grinders and know how use them. Put together a nice CL add but still maybe get only one bite/month. Every customer is always very satisfied w/results. Not sure what I'm doing wrong. (Perhaps I charge too much?)https://reno.craigslist.org/for/5875383139.html
I now consider it purely a hobby,which I'm fine with.
That is cool.
How long does it normally take you to sharpen a 20" chain?Yes,!the taker grinder philbert posted is the one he has.... how sweet is that....
Also the guy I know sharpens all chain at $5..... i have never asked him what the most common size he sharpens is.... my guess would be 20", but that is only a guess...
Wow, that cutter looks great!!!I've also have not had any luck with grinding chains for $$$. I've got decent equipment round/square/raker grinders and know how use them. Put together a nice CL add but still maybe get only one bite/month. Every customer is always very satisfied w/results. Not sure what I'm doing wrong. (Perhaps I charge too much?)https://reno.craigslist.org/for/5875383139.html
Oh man I don't know.....since I usually just do mine I am in no hurry.... I have done some as fast and accurate as I can, seemed to go quick, however I used to hand-file.... I would say if the chains ain't been used to cut concrete I can knock it and rakers out in 5-7 minutes....under 10 minutes for sure....Is that about right?!?!How long does it normally take you to sharpen a 20" chain?
Do your customers like the square grind or the round ground stuff better???
Takes me around 30 mins. What do y'all think about this. I just bought a older simington, prob paid to much, but was wanting to put more aggressive wheel on it to get all my rocked cutters close, without burning. Did I just waste my money? It's a older 450 and I'm pretty sure parts are no longer available.The cheapest the local Stihl saw shop will sharpen a 20" chain for is $12, (they don't do square either), so I set my price well below theirs. Can't see doing it for a whole lot less. I like to take my time and do a good job of it. 20-25 minutes for me is not uncommon. I have a small but loyal following takes a while to get the word out I guess...
Most of my customers bring me pretty rolled chain, 7 mins is impressive for someone just starting out. What are you cutting the rakers with?Oh man I don't know.....since I usually just do mine I am in no hurry.... I have done some as fast and accurate as I can, seemed to go quick, however I used to hand-file.... I would say if the chains ain't been used to cut concrete I can knock it and rakers out in 5-7 minutes....under 10 minutes for sure....Is that about right?!?!
