- 12:54 AM
- Dec 4, 2015
- In a meeting
Looks like alot of hook ??
Thanks for your report.I have only had it a few weeks so I'll give it a bit longer before giving a decent review. So far, I'm in Australia and they have been excellent to deal with. Contacted them to check a few things and they have been helpful and sent through some good info.
One thing I will say, the finish they leave is not what every mention I have found online has said. It's pretty rough, but it hasn't had any effect on the chains cutting ability or durability. Speaking to them they are aiming for a balance between cut rate, wheel life and finish. The wheels are mostly used on their auto grinders for harvesters and they move quick, so they aim more for that than polishing the cutter.
What it looks like. Keep in mind that's zoomed in, to me just holding it up it's fine but I know some people look for that super smooth finish and these wheels will not give that.
It is, had someone say you can't copy the C83/C85 factory grind so with minutes of experience under my belt I set about doing it. It's not hard but I don't recommend that shape.Looks like alot of hook ??
Going back MANY years, those were the first ABN / CBN wheels I recall being discussed in these threads. But $300! (looks like they have actually come down a bit; $245 in US).
The ‘cyclone’ cooling vents were also novel.
When the $100 wheels became available, a lot of guys jumped on those, based on the DynaSaw’s reputation. Questions about quality differences, grit size, etc., are still discussed to this day.
I was not impressed with a pair of $100 wheels I tried. Coarser finish, as you mention. And, I could still overheat cutters if I tried. Definitely less dust produced.
A rougher, sharp, cutter will still cut, but not what I was looking for. So, I went back to standard, vitrified wheels, which I lightly dress about one per loop, to clean them, and to expose fresh, sharp, abrasive. It takes a few seconds, and becomes automatic.
I don’t overheat cutters. And, I try to grind outside to address the dust issue. The wheels last a long time, and can be $15 - $20, in small quantities.
I am still interested in ABN / CBN wheels, especially if someone can get a smooth finish, either by technique, feed rate, brand, grit size, or other methods.
Philbert
That was an issue mentioned on some of the early, ‘Northern Tool’ / clone grinders, several years back. Some were not pressed on straight. Some guys knew how to pull them off, and reinstall them. Other guys just returned them and tried a different one, until they got a ‘good one’.one thing i have noticed is a lot of the units the arbor on the motor shaft is pressed on.
I think that they still have the reputation as being among the ‘best’ of that style wheel.They are $250AUD here so expensive but in the scheme of things the wheel and the cheap grinder work out at the same price as a new jolly Evo grinder.
It was with one of the solid, $100, CBN wheels, and I was pushing it to see what it would take (not as much as I expected).I'm sure anything is possible but if you burnt a cutter with this wheel I would be surprised.
The little card that comes with the wheel mentioned coolant but I think that's more for the bandsaw sharpening side of things. I might as them if anyone is interested.on the cbn wheels something in the 120-150 range is very fine for steel 60/ 80 likely wood be ok, but as you move up to a finer finish so does the heat factor same as vitrified stones. likely would need some type of coolant spray continuously ,just air blow by function would help -less messy ,applied to cool the tooth and the wheel. dust/grit collection becomes more difficult though. I get too many varieties of chains to do. It's much easier and cheaper for me to just dress a wheel for the tooth encountered. Can't do that with cbn . I get the "not to have too dress the wheel " thoughts and the life span.
Motors the tecomic & oregon motors are better than most of clones units. Funny though that the only motor I have fried was an oregon one in 30 years. Luck of the draw or lack there of. The replacement was around $300 that was a number of years ago. one thing i have noticed is a lot of the units the arbor on the motor shaft is pressed on. I have spun several of those loose over the years. They all seem to be alum. of one type or another.
I’m not mad at that
It's not bad in my opinion but I know others are looking for a smoother finish. There was not much info out there before I bought it so I'll try and share what I can to help others thinking of buying one.I’m not mad at that
Not sure if I'm allowed to throw up a video in here but here's a few minutes of using the ABN wheel and trying to heat a cutter
Can a fellow get one here in the states I wonder?I also just bought a wheel from DinaSaw during their sale, im finding it great, the finish is coarser that the old pink wheels ive previously used but im happy and chains are sharp.
They run very cool and I doubt I'll ever burn a cutter.
Go to eBay. Around $200 shipped to the States. I assume it’s the same company.You can. They ship worldwide.
BUT
I just put one wheel in the shopping cart and my address and shipping was calculated at 550 Australian dollars. Ouch!
775 Australian is 408 UK pounds or 520 US dollars.
BUT
