CoreyB
- 3:42 PM
- Jan 26, 2016
- South east iowa
Me tooI don't know the difference. The 12b is more common from what I remember seeing
View attachment 112430View attachment 112430 From what I know the 12-1 is for a lot smaller saw than the HD12b.That would explain why it is cheaper. Lol.View attachment 112430 View attachment 112430 From what I know the 12-1 is for a lot smaller saw than the HD12b.
Is it an HDA 12-1 which is what I’m basing my reply off of.
View attachment 112432 View attachment 112431 View attachment 112430View attachment 112430 From what I know the 12-1 is for a lot smaller saw than the HD12b.
Also an HD6-1 listed
The hd6 has a little smaller Venturi than the 12 I believe if I’m not mistaken.The HD6 was the pre-EPA carb used on the 372xp before they switched to the HD12B when the EPA mandates hit. I feel like the 12B has a slightly smaller Venturi, but I don’t have numbers in front of me.
@SawTroll.
HD12B carbs are cheap and plentiful on the bay.
I think I have 2 spares, and I’m sure @Mattyo has some too.
They don’t really go bad either. No accelerator pump to fail or crazy impulse setup like on the HDA199. They generally only need a new carb kit to run. Although I have heard from some people that they are hard to tune or finicky compared to the Zama option, but I never felt that way about mine.
So the 12-1 is the same as the 12b?6 is smaller. Walbro lookup does not use the a/b suffix its always -1 as in hd-12-1, hd-6-1.
Shep
As I understand it, the difference is about Walbro and Husky using different designations for the same thing - but I can't confirm that 12b (always) is exactly the same as 12-1.I don't know the difference. The 12b is more common from what I remember seeing
@SawTroll.
