Carb help please HD-12b Vs HD-12-1
CoreyB
10:37 AM
South east iowa
Hey guys quick question. I have a 372 that i am working on that needs a new carb. I can get a HD 12b from Husqvarna but through walbro I can get a HD-12-1 For almost half price. Is the hd-12-1 the same as the HD-12b
Any clarification would be awesome
@Poleman Do you know?
11:37 AM
I don't know the difference. The 12b is more common from what I remember seeing
CoreyB
10:37 AM
South east iowa
It is more confusing (at least to me) that the 12b is not available through my walbro distributor . Just the 12-1
Poleman
9:37 AM
Rapid City,S.D.
That’s what I was thinking...
I doo have this in my drawer....off a 372 I put a Modded Zama on a while back....92B720A5-C865-4C92-BE5C-C2F8B189D5AB.jpeg
decableguy2000
11:37 AM
WNC
Go with the cheaper one, part number labels are expensive. When you search Walbro's site, by hd12 the only one that comes up is the HD 12-1
Derf
11:37 AM
Long Island NY
I believe that the 12-1 and 12b are essentially the same, the differences pertain to things like which side the throttle linkage and choke plate hook up to. For some reason I think Walbro made the carb in different configurations for different applications : Husqvarna’s 372xp saw has the throttle on the left and the choke on the right. But I believe when they had their 2-series, like a 262, the choke was on the left and the throttle was on the right. So the B designation may indicate which way the throttle / choke shafts are set up. Maybe also small other differences like fuel inlet pipe orientation, but I’m less certain about that.
Perhaps you can swap things around from the 12-1 to the 12b.
But all of this is just hearsay, IMHO, $ 0.00002, etc.
Derf
11:37 AM
Long Island NY
View attachment 112432 View attachment 112431 View attachment 112430View attachment 112430 From what I know the 12-1 is for a lot smaller saw than the HD12b.
Is it an HDA 12-1 which is what I’m basing my reply off of.
Also an HD6-1 listed
The HD6 was the pre-EPA carb used on the 372xp before they switched to the HD12B when the EPA mandates hit. I feel like the 12B has a slightly smaller Venturi, but I don’t have numbers in front of me.
@SawTroll.
HD12B carbs are cheap and plentiful on the bay.
I think I have 2 spares, and I’m sure @Mattyo has some too.
They don’t really go bad either. No accelerator pump to fail or crazy impulse setup like on the HDA199. They generally only need a new carb kit to run. Although I have heard from some people that they are hard to tune or finicky compared to the Zama option, but I never felt that way about mine.
11:37 AM
@SawTroll.
The hd6 has a little smaller Venturi than the 12 I believe if I’m not mistaken.
SawTroll
Information collector
5:37 PM
Troms, North Norway
As I understand it, the difference is about Walbro and Husky using different designations for the same thing - but I can't confirm that 12b (always) is exactly the same as 12-1.
I suspect that it hardly matters though?
SawTroll
5:37 PM
Troms, North Norway
@SawTroll.
If the specs that Walbro used to list were to be trusted, it actually was the other way around - the HD 6 had a 16.67mm venturi (same as the HDA 199 and HDA 87 btw.), while the HD 12 has a 17.46mm one.
This beats me regarding logics, but nobody has claimed that the Walbro specs are faulty in all the years I have been on forums like this - I still have my doubts though.
Another difference is that the HD 6 doesn't have adjustment limiters, while the HD 12 has (EPA related). My logic tells me that this should have been the only difference, but apparently not?
