can we have basic porting term thread?
cobey
4:50 AM
Pittsburg, kansas
What to measure?
I know how to find TDC
So intake open /close?
Blow down?
Exhaust open / close?
cobey
4:50 AM
Pittsburg, kansas
Just want a list of significant
Timing events to measure
:jump1:
SixGun
5:50 AM
Hackettstown NJ
What to measure?
Blow down?
Exhaust open#,
Transfer open#.
(The difference between exhaust and transfer open is your blow down.)
Intake open # ( measured in degrees before TDC )
These are your starting numbers, duration can be calculated from here
cobey
4:50 AM
Pittsburg, kansas
Exhaust open#,
Transfer open#.
Good info thanks
SixGun
5:50 AM
Hackettstown NJ
To find duration,
Exhaust or transfer open # subtracted from 180 multiplied by 2 equals duration#
Example- (180- 100=80) ( 80 x 2 = 160) exhaust opening at 100* has a duration of 160*
To go from duration to open # , do math in reverse.
For intake, simply multiply open# by 2
Guys, please correct me if I'm wrong
Hedgerow
4:50 AM
Good info thanks
This is how you get to know the saw you're about to work on.
Sometimes you have to figure out what the original designer had in mind for it, before you can make improvements.
There are other factors to consider also, as #'s that make an awesome 372 will not help your cause on a 7900 or 044.
cobey
4:50 AM
Pittsburg, kansas
Probably be a couple day's before
I get numbers ,
I might have to teach tomorrow night
cobey
4:50 AM
Pittsburg, kansas
It's a head banger without the gasket,
022 ish with it. I have half a thought
Of putting it together and seeing
It everything works before
I do more
5:50 AM
I do more
That's a good #. Check a few places and if using solder, roll the flywheel over TDC a bunch of times to get a better reading
lumberjackchef
4:50 AM
Southeast Kansas
