- 12:48 PM
- Dec 31, 2015
- East Jordan, MI
Jeebus. I thought an ms361 sucked. That's a Mongolian clusterphu.....
He said ratty not shatty lolChinese are real cheap
Echo. Ok I missed something. What you workin on? Echo il follow thatThanks to the help of one of our members here, a new top end has been ordered for the little Echo.
The price was very reasonable too. Hopefully I have better results from the next jug. lol
Found it. My guess something stuck in the muffler went un noticed
Anything is possible Pat. It's not something I like to do on a work saw though.
No sir. The only reason they are taller is to allow the port to be really steep.
No sir. The main passage is a little bigger.
Maybe I have missed it somewhere in the annals of the various porting threads here, but what's the theory behind the 2-stage transfers??
some relatively young members too. @Deets066 @Canadian farm boy @drf256 @Chainsaw Jim all come to mind. I'm sure I'm leaving some folks out......and I assure you it's not on propose.
Oem or Meteor piston for this one, Brewz?Attacked my 044.
It wasn't running great and it had never had a full rebuild so it got one.
When I opened it up I remembered I had only widened ports but not really changed timing.
It was at 105/124/75
I took .020 off the band, set squish at .019 and ported it to 102/120/78.
I had a bit of a play with leaving a step under the exhaust floor but the sanding drum took the top off it on one side which upset me a tad but it will be fine.
I didn't go too wide or too flat as its a work saw.
Also ditched the original HD carb and fitted up a WJ6A I bought from @Redbull661 that was modified by @tree monkey
Gunna get it in some timber tomorrow.
Cant wait!
I bet it gains a bunchAttacked my 044.
Cant wait!
Reused the original OEM piston and rings as they are fine.Oem or Meteor piston for this one, Brewz?
The numbers on the left are where the port heights are after machine work. On the right are my target numbers.
