hotajax
- 7:22 PM
- Dec 10, 2020
- Eastern PA
I know the answer may be fairly obvious to some, but I'm puzzled. I saw a you tube with a bore snake with a weight on it. Put the weight through the barrel, and pull on a small cable that pulled the snake through the entire length of the barrel. Here's the confusion: I was in an outdoor sports store yesterday, and they had a bore snake without weight on it. It was plain as day that the diameter of this snake would definitely not allow it to slide through a .22 barrel using gravity only. So what's the deal with using these things? If you can turn the light on for me, I'd greatly appreciate it.
