- 3:46 AM
- Jan 24, 2018
- Extreme Southeast CA
I tried chasing a seam crack on a MS 391 (found out later that the guy dropped a tree on the saw) with JB weld. Didn't work, the thing kept leaking, from where I don't know. Spent $30 and got a used case on e-Bay.But I think it’s the case gasket. I’m not about to split the cases just for that, any bandaid ideas?
You got a spare few hours you could send me? ;-) maybe this summer, indoor season. I think I did check the front case bolts.How about taking the time and repairing it correctly, unless the saw is not worth repairing.
It still runs out of gas before the oil so that's good. It'll probably wait til summerHow much is it leaking?
Just run it as is and dump the oil when storing the saw?
It's basically what I do with my pissy Dolmar's, just a couple of the large frame ones actually.
Reroute the oil and fuel lines?
That way You won't have no more oil leak!
Plastic tank I just fixed on a 250, cleaned well with rubbing alcohol and plastic welded it with zip ties and a cheap harbor freight soldering iron style plastic welder that was 30$had a tank leak like that on a steel 201.
i emptied the tank,, super cleaned the tank in and out,, ethered it .
then forced permatex ultragrey in the void until i saw it coming inside
let dry for a few days,, been over 2 yrs and so far so good.
Cant hurt to try
I did pretty much the same on an Stihl 026 only used, high heat silicone and it worked. Used the saw years and sold it. I did loosen the case screws prior to cleaning and then tightened them back after some drying time.had a tank leak like that on a steel 201.
Cant hurt to try
Every cut. Dry hard dusty wood you know. You come carry the bucket.He could just run it with the oil tank dry, carry a bucket of oil with him, and dip the bar every other cut.
