Backtroller
- 12:49 PM
- Dec 31, 2015
- Land of Badgers
Maybe they’re doctoring numbers like VW did with their diesels
In Europe Echo states "Maximum shaft brake power (ISO 7293) 3.32 kW", which is the same as 4.4 hp listed in US.Look at the fine print on the hp rating.
Says baised on the epa website rating....
Could have detuned ones to meet emissions, or they are saws abroad.
Not in US, but in Europe they have to publish the power numbers, see manuals e.g. in https://www.echotools.com/en_us/support/manualsI don't recall ever seeing any actual echo published numbers.
They indeed can, but there is the ISO. I don't see that in Husqvarna manuals, but Stihl announces "Engine power to ISO 7293: xxx kW (xxx bhp)".All of the big companies can develop their own test procedure to get the hp/tq rating.
This is the opposite case - VW wanted lower emissions, but why would Echo want lower power?Maybe they’re doctoring numbers like VW did with their diesels
edit: Multi-answer![]()
I don't recall ever seeing any actual echo published numbers. I remember that was saw trolls big arguing point.
Unless you know the correction factors /perameters they used it is very hard to say for sure what the issue is.
Same reason you don't take your car to 5 different dyno shops to see the difference in your changes. You will get 5 different ratings.
Just as likely to take 5 of the same model saws out of their boxes and get 5 different ratings ont the same dyno. While today's manufacturing tolerances have tightened up from old, there are still "Wednesday" and "Monday/Friday" saws being made from what I can see. This too would be interesting to see played out on paper.
Would be fun to dyno a euro spec saw..
From what I could dig up in that iso is had started in the late 70's and the last revision was in 1997, believe it has been replaced now. Really don't feel like buying the complete iso info file. They don't appear to share the info freely.
Could be part if the reason the stihl 660 was so close to book spec?
I am going to guess it has something to do with us emissioms... why is echo about the only one still running carbs, and how can they continue selling a the 680/800 those have to be "dirty" saws by spa standards?
More questions than answers at times.
Sure would be fun to know.
Who has five of the same model in the box they want run?
Lol
I do have a pair of stock 261c here.
If a company has models that beat the "zero" base line for emissions the EPA gives them credit to use towards models that do not, theory being that together they all average out to that "zero" base line. That's the way I understood it.
Over time though as you go you should be able to get a good picture painted as you do more and more saws though.
Ahh, I had heard something about that.
And in the little bit of reading I could on the iso testing. It made mention of fuel usage, and power testing.
So some of the ultra efficient small saws make up for the bigger saws. De tuning makes sense on some of the other just to make sure you get a pass?
Idk all speculation.
I think I remember echo posting hp numbers for the 501p, the 355t, and the 620p. But that’s all I can think ofI don't recall ever seeing any actual echo published numbers. I remember that was saw trolls big arguing point.
Ever tested a 10hp elektro motor as reference?
