Another chainsaw dyno...
12:15 PM
Need to get around to trying it.
But curious to find out the hp% gain vs the cut time % drop.
Is 25% more hp 25% quicker cuts?
Fun fun.
25% more power seems to be more than 25% faster times. Don’t know how, but it sure seems that way
Red97
12:15 PM
MI
Example
4.5 hp to 5.63 = 25% power gain
36 sec to 27 sec = 25% quicker cut
That 11 sec seems a lot harder to get than the 1.13 hp?
Sure would be nice to figure out the ratio.
12:15 PM
Example
I was going more by cc’s than hp.
In my experience, 25% more cc beats up on 25% faster times
Terry Syd
2:15 AM
Comboyne, NSW Australia
Perhaps it has to do with the cutting angle on the chain. When you can produce more power, you can use a bigger cutting angle (lowered rakers) to take a bigger bite of the wood.
That's why the dyno is so good. You can eliminate the chain and wood and just look at the powerband. When you get the best powerband you can, then tweak the chain to the engine and the wood.
Deets066
AKA Deetsey
12:15 PM
Example
Just like cars at the drag strip. It’s not hard to get a car to a 10 second run. But it’s starts to take a lot more HP to gain time after that.
Red97
12:15 PM
MI
Exactly. Muffler mod and timing advance is good for a nice drop in cut times. Is it 1:1 For the first 20% then more like 20% more power to gain another 10% quicker cut time ?
I need to get a few more saws on the dyno.
The torque I thought I felt in some of these bigger cc hasn't been found on the dyno.
I know I don't pull a saw much if any below 8k in a bucking cut on purpose.
So far the smaller saws have had more hp, and tq across the board until under 7k.
I have a hard time seeing the power under normal in cut rpm making a difference.
Maybe if you start the saw in the wood it may make a difference. From idle to max rpm while dogged in.
From full throttle over the wood, I can't see the tq/hp made at 7k and below coming into play. On a saw tuned to 13k and working in the 9k + rpm in the cut.
Bigmac
9:15 AM
Oregon
The times when the lower end power is needed is falling cuts, were you would be off and on the throttle in the cut, and long bars were you needed to accelerate the chain in the cut from an idle. But they are minor.
Red97
12:15 PM
MI
I could see that.
I'll have to grab the tach and see where the clutch actually grabs with some load applied.
Like having the chain set and powering up from idle.
CR888
2:15 AM
Australia
Often we see 'same bar/same chain' cut tests too compare powerheads & eliminate the variable of different chain. But...to get the most from a bigger or more powerful saw you really need to match the chain to the powerheads. Racing chains vary quite a bit from a 3cube chain to a 5cube etc. The dyno cares not one bit about this and purely judges a saw right off the crank.
Member
11:15 AM
Fun fun.
Lots of wood variable there, I've gotten as much as 50% better cut times in a certain piece of wood, and there's no way power was increased by that much. Still would be interesting to see what you come up with.
