Another chainsaw dyno...
Red97
4:02 PM
MI
I thought max hp should be the actual max hp on the graph. NO?
The numbers listed are the power at the thin vertical red line.
I can only pick one line, normally I pick the peak hp of the ported saw. Unless that peak is way higher than the stock saw.
On the 372 graph the line is at 10,100rpm. You can see that rpm listed in the far lower rt hand corner of the graph. Whatever rpm is in that spot is the rpm the numbers come from.
