Another chainsaw dyno...
3:46 AM
Oh well, the troll had a bad attitude but some good points.
I think he was trying to say that an engine optimized for running on higher octane fuel could make more power than a low octane designed motor.
Octane is the relative speed at which a fuel will burn as compared with 100% hydrocarbon. The longer the Hydrocarbon chains in the fuel, the slower it will burn. It does burn slower, so it needs more advance to have time to fully burn. The slow burn means it’s less likely to pre-ignite (detonate) and fire before the piston can take advantage of the pressure change the combustion creates.
Full burn quickly creates the highest cylinder pressure and most efficient use of fuel, but we are limited by various factors (aka variables). Generally, the higher the number of carbon atoms in a fuel, the more total heat it will produce-more bonds need to be broken for the oxidative/reduction process. But it takes longer, so we are looking for the quickest pressure we can build in a cylinder perfectly at TDC.
Saw engines may not differ than other 2T engines by design, but there use in their powerband certainly does. Saws are meant to be used at WOT and really not in between. Because of this, they do tend to run hotter than other types of engines.
All compression does is preheat the fuel/air mix to the point where it’s just about to ignite so that it can have the most time to burn before the burn is useless (won’t add cylinder pressure that’s meaningful). So higher octane fuels can be compressed more, generally contain more hydrocarbons, and should make more heat per mole of substance if burned efficiently.
When a saw gets hot, it needs less compression and less advance to burn fuel efficiently. You’ve all heard a saw 4 stroke and then clean up in the cut. Once you ask a saw to do work, the cylinder temps go up and the saw suddenly can burn the fuel without misfire.
I see the “theory vs reality” argument here. But science is science and it’s truth are generally born out though-out time. It’s all physics. Remember Newton’s laws. Energy can neither be produced or destroyed, it only changes form. In an engine, we are converting potential energy in fuel into kinetic energy. Heat is the byproduct, so the more heat you lose, the less total power you are getting out of that fuel. The VE of a saw comes into play here as well. There are a lot of pumping losses, so a saw that’s 250psi while pulling the starter rope won’t come near that amount of static compression when the cylinder has a millisecond to fill at 14K.
So pretty much, by design, saws dont need high octane fuel to perform well. They need a fuel that’s compact in heat/ml that will create a lot of energy -like gasoline that burns at 14.9:1 stoichiometric ratio. The speed of the fuel burn plays a role when you’re running at WOT over 10k for nearly all of its run time. High octane fuel will just be wasted by not taking advantage of the full burn.
Think I confused myself. Hope this makes sense. I’d also be willing to toss in a few sheckles to see what Joe can prove on the dyno. My bet would be that there will be a negligible difference between high and low octane fuels.
Jimmy in NC
3:46 AM
North Carolina
To add to the last post... Mahle did extensive testing in small single cylinder engines. What they found was there is a point that RPM is above a threshold where pre-detonation can occur. Their testing was on motorbikes but it applies to saws too. With the fixed timing and stationary ports at high RPM you simply cannot make power simply by changing fuel.
What Mahle found was actually power was lost using slow burning / high octane fuel as their was inadequate time for a complete combustion before the exhaust opened.
Woodpecker
Sassy Madam
3:46 AM
"Oh well, the troll had a bad attitude"
Solidly reasoned post Doc. Made perfect sense. The problem wasn't what he was saying but in how he was saying it. When it becomes apparent that you are only drudging up an age old argument from at least the days of Mac racing carts simply for the sake of being an argumentative dink, your bound to earn yourself a vacation.
srcarr52
3:46 AM
Iowa City
The benefits of higher octane fuels diminishes in smaller displacement cylinders such as a chainsaw. The short dwell time and relatively slow squish velocity compared to larger engines negates the need to run higher octane until the compression ratio gets extremely high, but at that point the high compression becomes detrimental to power in the upper RPM range of the engine. Sure you can add more timing with higher octane fuels but that only breaks even with lower octane fuels when you can't add enough compression to take advantage of the fuel.
Saw Collector
OPE Member
3:46 AM
Here
I remember being the new guy. I also remember being treated like *s-worde by some of the members here because of my views or findings. I also lashed out, in a much more severe way than this guy did. Why am I still here and not banned. Had he not been treated like *s-worde from the start he probably wouldn't have turned into that dink. This place isn't very accepting of different opinions, ideas or experiences if it goes against the folds beliefs. The way he was responded to almost immediately would have gotten a similar response from me. I guess tou can lump me in as a troll as well.
cus_deluxe
terms of service violator
3:46 AM
Michigan
#weedwhiptroll
lol.
2:46 AM
No...you were actually a reasonable person from the beginning. This guy was different Steve. I cut him loose...and am good with it.
First he admitted that he had basically zero experience with these short stroke high rpm engines, then he proceeded to tell everyone who had literally decades of experience that they were morons.
I've seen a bunch of guys like him come and go over the years. They know more than anyone else, and cannot be bothered to hear what anyone else has to say.
3:46 AM
What's this thread about anyhow?
This thread is about what the whole forum wants to know ... How much can we improve on the performance of a chainsaw!
And I have to say, the #s do not disappoint those of us who either mod, or have mods done by others, to our saw!
This thread is the Holly Grail of this site! It proves that it is not just a sharp chain, but that the powerhead mods matter!
3:46 AM
Sorry, but I just have to add this:
Octane Rating
An octane rating, or octane number, is a standard measure of an engine or aviation gasoline capability against compression. The higher the octane number, the more compression the fuel can withstand before detonating. Octane rating does not relate directly to the power output, instead octane rating simply refers to gasoline capability against compression. So, the octane rating has nothing to do with its energy contained (per-litre or per-kilogram). In broad terms, fuels with a higher octane rating are used in higher-compression gasoline engines that potentially yield higher power. Note that such higher power comes from its higher compression of the engine, and not necessarily from the gasoline.
    Wikipedia
Woodpecker
Sassy Madam
3:46 AM
I'll explain because I like you Steve and it's worth the clarification. Quite simply his argument is an old one that he used as a vehicle for the sole purpose of arguing/trolling. Similar but different than your situation. There are lots of previous bad actors out there with chips still firmly in place on shoulder.
Red97
3:46 AM
MI
Classic? Or wavy chip?
