Another chainsaw dyno...
Red97
11:23 AM
MI
oof - It seems like they're free, as many as we use in our test lab.
They are also quite reliable as long as you're not side-loading them, over-straining them, etc.
Be sure to 'carefully' tighten those jam nuts too - I'm assuming you know this, but I noticed it in your picture.
I know some are less $$$ I was hoping this was more expensive just because it was a better quality.
It is a 250lb sensor, he set the amplifier for 100lb range and even with the 2-1 It should be good for 50ftlb before I go over the amplifier. But still well under the rated load.
Yes I read that part if the instructions, that still needs some fine tuning make sure everything is in line and tight. No wiggle/rattle
Lee H
8:23 AM
cape cod ma.
Uncle in case you didnt get the memo
We said "break in" NOT "break it" AGAIN!
Lol, how are ya. Haven't seen you here for awhile
Sent from my INE-LX2r using Tapatalk
Ya Ya Ya buddy. I been around here and there. I don't think my saw would break the dyno,
Not now anyway. Hope everything goes well with it now.
Red97
11:23 AM
MI
Adding some bling.
The data boxes will mount on this bar, which is also rubber mounted.
Bling is to help protect the boxes from stuff falling off and onto the boxes.
Busted a tap in one of the holes. Extra antivibe material I guess.
Red97
11:23 AM
MI
Boxes mounted...
Load cell mounted.
New rpm trigger.
Pretty sure all the hardware is hooked up/done.
Now I just have to figure the software/calibration.
Getting closer.
