wcorey
- 10:17 AM
- Dec 11, 2015
- ma usa
Certainly appears that there's separation on the edge of the pad where it's highlighted.
Unfortunately looks like the pad itself is pulled up and not just the wire from the pad, generally that's not good, but hard to tell on this pic.
Try to clean up around the connection as much as possible and touch it gently with as small a soldering iron tip as you can find. Make sure the wire is held in place so it doesn't spring up when the solder melts. Try to heat it as little as possible to just melt the solder, in and out quick, don't want to melt into the cell.
And not too hot on the soldering iron, like 6-7 hundred, not 8. If it's not temp controlled, try touching some flux core solder to it and if the flux really sizzles/smokes, try unplugging it and see how long it takes before the solder wire won't melt. Use that unplugged window of time to do the connection.
You might get lucky and it reconnects.
Does seem odd that it only uses 3 wires...
