85cc 064 porting
jmssaws
Banneded
9:25 PM
Hmmmm. Im wonderin if piston weight is why huskies drop bottom bearings
A 94/5 piston is giant and it hurts them.
I can't get one to run with a strong 066 anymore and I think that's some of it.
They just won't tune as fast and if they did it would be very short lived
Keith Gandy
Maxima K2 40:1 87 Pump Gas
9:25 PM
Provencal, Louisiana
Thats odd though in that 390/4/5 spool up so quick with the weight
Definitive Dave
Piss Rev Mafia Member
10:25 PM
Central Ohio
The only limited coil for a 64 was on the 066 red light Dd has a thread 064 66 coils and flywheel combos
I think this is correct ?
almost right, there are different limited coils for the 064 and the 066
somewhere that thread has pics
EDIT: I should have kept reading the thread :)
Glock37
10:25 PM
Monroeville Pa
How far off is your numbers from everyone else that ports
jmssaws
Banneded
9:25 PM
I don't use a set number and never build one the same,the cylinders vary so much I just go with what It gives me.
Low exhaust makes tourqe and a high exhaust makes rpm they sat but I've seen it the opposite.
Fastest tuning saw I've seen had the lowest exhaust and least intake duration than any I've done.
Exhaust at 102.5 and intake at 77 but tunes over 16k
