Adirondackstihl
- 6:19 AM
- Dec 4, 2015
- Upstate NY
Farmertec clutch.The last powdered case had that in this area. I used my Dremel with a wire brush and removed it. Worked fine. Is that an OEM clutch or one from across the pond? The reason I ask is I bought a clutch for a smaller saw and when I spun it on yesterday there is certainly something awry -- it wobbled going on like a rim with one lug nut on . Needless to say it came off immediately.
No problems with the clutch as far as fitment.
But the clutch drum.......well that didn't fit right.
It was rubbing on the aluminum oiler hose and the brake brand.
Installed used OEM clutch drum.......problem solved.
