394 or 395 which do you prefer?
Miller Mod Saws
Chainsaw Masseuse
4:35 AM
Ravenwood,MO
I've seen some of the 94's you built Carl and they look strong, there both a saw that loves porting even though a 394 is the only saw I've ever used that I could live with stock. Really good saws.
I build and own 066's and occasionally still cut timber but I only cut down with my 395.
You seen a slow saw then. Lol. As I was playing with them I noticed for me and running a 36" bar and using then to noodle I really like the 103 exhaust height. I now they would be faster at 100 but man O man. And your right. Stock for stock. The 394 is stronger especially if ya set the squish. If they only didn't have that stupid outboard clutch. Lmao!
mdavlee
Hillbilly grinder
5:35 AM
TN
I like the outboard. On an inboard one long cut boils bar oil on a mill. I can get 2 if it's not 100° with a 395. Big difference in how much heat is made in the clutch area. This 066 I got has the plastic around the drum burnt.
MG2186
4:35 AM
Summer,IA
What's the reason for liking one style of clutch more than the other?
pro94lt
4:35 AM
South
Low top or high top? I kinda like the low top better for actually working but I like to set the 395 xpw high top where it can be seen. The 395 is eye candy
jmssaws
Banneded
4:35 AM
My 94 is a high top but I have the low top setup, I do like the high better,love the big filter.
CR888
8:35 PM
Australia
I like them big clutches on the 395, I agree with Mike with regard to outboards keeping heat away from the powerhead, seals, bearing and crank. Gets to release its heat better too. I like both designs for different reasons but many of the best big & small saws of their day have the outboard clutch. 090 ms200.....
5000+
5:35 AM
pa
It takes a very long time for even the low top filter to even get a little dirt on it. The air injection works way better on the 394 than others, the 346 doesn't work nearly as well.
Wolverine
dilligaf
5:35 AM
I'm shocked at how long the filter stays clean.
I converted mine over to the hd filter a year ago. Milled a bunch on top of my usual firewood gettin'. You could easily mistake my filter for a new one. It has been by far the best functioning air injection system I've owned.
