394 or 395 which do you prefer?
psuiewalsh
Basement Bodging
4:03 AM
Nottingham,pa
srcarr52
4:03 AM
Iowa City
Looks like it is to use the 395 cylinder on the 394 case
Same case, no difference. The cranks have a different end for the flywheel side, that's about it for differences on the bottoms end.
Use NGK plugs, the Bosch plugs crack the porcelain up inside the plug and will short out there when hot. The spark is enough to keep the saw running but not enough to restart. Once it cools down the crack tightens up and it starts fine.
I've switched to all NGK plugs in huskys.
jmssaws
Banneded
3:03 AM
I've not ran a 661 much but I've ran a 395 a bunch and there very strong.
jacob j.
Only the weird
1:03 AM
Coastal Oregon
If both are stock- I like the 394 better. It has a wide torque band. Modded then the 395 becomes a beast.
The intake boot design on the 395 is better for the long term as the intake blocks on the 394 have a tendency to crack- usually around the impulse channel.
I've built every combination of these saws possible including ones with 372 X-torq carbs, machined out squish bands with 2100 pistons, full-circle cranks, etc.
You can convert the 394 over to external impulse with the X-torq carb and bypass the problems of the intake block (including the hot re-start issues).
CR888
7:03 PM
Australia
They're monster saws the 394/395, I consider them more a 100cc class saw than a 90cc class saws. I wonder what the future holds for an upgraded 395xp? AT, layed back angle cylinder, new improved AV, new master control? Its a shame the market is so small for this size saw, it seems like a generation passes before something new comes out. Husky have the knowledge to really make a big improvement in this model when they decide to do so. Not that there is anything wrong with the 395xp......with todays tech it could be so much better. I want 2 C a 595xp with an AT system that has settings (modes) for short bar, long bar and milling.
