346 porting (first time)
paragonbuilder
11:12 PM
Norwich, CT
So should I clean the squish up with some finer sandpaper or 80 grit is ok?
Mattyo
Youtube speciawist
11:12 PM
Farmington, CT
I'd probably leave it, but what could it hurt to throw some 220 grit at it?
the only question I have with doing it this was is what happens to the very edge ...the corner where the cylinder wall meets the head...is it rounded in such a way that the cylinder needs to be rounded as well?
redoakneck
11:12 PM
Ohio326
Anyone who has done the 357/359 carb and intake conversion, does the new intake tract seem pushed to the left and slightly out of Allignment with the pins on each side??? The air filter opening is right in the middle, so it is centered, just seems to be tension especially where the choke and O/I switch are???
I just did one last night, and oh yeah, do you really need that little blue ring on the inside of the intake boot:mad::confused::confundio1::copas:
paragonbuilder
11:12 PM
Norwich, CT
Ok so this saw was apart when I got it. I'm baffled. I've got the fuel line on.
This line
Goes here I think
But what about this one
When I push the fuel purge it shoots fuel out???
What am I missing??????
paragonbuilder
11:12 PM
Norwich, CT
Other than that and some fresh fuel she's ready to go!
redoakneck
11:12 PM
Ohio326
Prolly the purge dump back to tank. Need to hook it up to most forward nipple on tank. Remove carb box floor, see if you have an open nipple
paragonbuilder
11:12 PM
Norwich, CT
That was it! Thanks!
Not sure why it was up through the carb floor, but we should be good to go tomorrow!!!!
paragonbuilder
11:12 PM
Norwich, CT
Got it back together. Tomorrow morning I'll look at his bar and chain, touch them up, put some fresh mix in her and hopefully get a good video!
paragonbuilder
11:12 PM
Norwich, CT
Ok.
I plugged the decomp. When I did the vac test I had to mess with it to get it to seal. Plus who needs that on a 50 cc saw?
My dealer didn't have a ring [emoji35] so it's got the old one in it for now.
Dressed the bar. Put a nice aggressive edge on the chain. Fresh fuel. Popped on the third pull. Fired up but I couldn't get it tuned. High screw all the way in. Pulled the filter. That was better. So I took brake cleaner to the filter. Much better now!
Here is the video.
Having a hard time telling the difference between 4stroking and the limiter. How's the tune sound?
paragonbuilder
11:12 PM
Norwich, CT
Played with the tune a little more. I think I've got her rich enough. What do you all think?
She's a strong saw! But I've yet to run a 346 so I've got no comparison to stock.
Here she is noodling in white oak.
