3 cube chain
Hedgerow
10:54 AM
I went 1st, 2nd, and 3rd in the 3, 4, and 5 cube last year, and came home with a whopping $50..
Can't see that happening again.. Lol.
It was a good time though. Got to meet some of the Stihl timbersports guys.
Cut4fun
Redneck Chainsaw Repair
11:54 AM
Ohio
Says $90 for all chainsaw events if paid ahead. Do wonder what the payouts are this year, but he didnt say.
16" for hotsaw = bikesaws if they show up.
10x10 SA and gas
concretegrazer
10:54 AM
Mo
Yes...
We can do that.
Kool. Need the cutter to be any specific length? Ill get one ready after i finish up this stupid .404 loop.
Who's saw are going to run this on? Need a dl #.
Hedgerow
10:54 AM
60 DL would be the common bar size.
As long as they're similar, we should be able to grind bout any cutter.
Cut4fun
11:54 AM
Ohio
UPDATE on MO show
I was just contacted and he is changing hotsaw wood size to 14" = to even things up better were going to change the hotsaw wood size to 14". Thanks
Cut4fun
11:54 AM
Ohio
I knew this was the reason. But here you go. Also we've decided to change the hotsaw wood from 16" to 14" to accommodate the 3120 saws
CR888
1:54 AM
Australia
Anyone read the article Masdens have on their site about a square filing contest Oregon did between about 12 loggers who use square chain. They idea was that Oregon new experienced loggers would change off the roll factory chain to suit what they were cutting & file faster chain than factory grind. Anyways the results were interesting in the fact the best 'looking' chains were not the fastest. Those who left a step in the gullet were the top performing chains. I've read this before from a hotsaw competitor who insists you can't remove all the gullet to the side plate & that natural 'step' that filing creates is important. Its not something I see around here, everyone removes all the metal in the gullet possible which looks like the right thing to do but perhaps is not?? I didn't pay much attention to this when I first read about it but after the Oregon sponsered filing contest finding the top few chains had this in common it got me thinking about it. Apparently the old school loggers have known this for ages & do it cause it works. If you posted a pic of one of these cutters here, the first thing someone would say is 'that gullet needs tidying up'. Thoughts?
mdavlee
Hillbilly grinder
11:54 AM
TN
I've never seen the gullet stay on make a faster chain. I've done them in steps and the gullet knocks off some time. Is it necessary in a work chain? Doubtful it makes enough difference to do it every sharpening but when filing it makes it easier to file.
jakethesnake
I Am The Snake
11:54 AM
Here & Now
The gullets were mentioned in the article. And said they cleaned them after the race & cut times decreased.
watched a video with old man walker from walkers saw shop He said leaving the gullet helps clear the chip out the back of the tooth. He didn’t say it was faster. He said the chain would cut straighter in longer cuts. Voodoo
