3/8 X cut.
Jscb1b
Mister Slapnut
12:40 AM
AZ, USA
How come 3/8 X cut uses a 7/32 file instead of a 13/64 file? Does it clean out the gullet better?
Squareground3691
3:40 AM
New England
The file size, it’s all spec out by manufacturers , for the average consumer, whatever gets you the best cutting edge according to ur conditions and wood ur cutting, it’s all about experimenting and finding what’s works for you, file sizes are kinda a choice,
3:40 AM
Most recommend 7/32. Stihl recommends 13/64. Might be so guys buy more of their files due to being proprietary. Might also be because with their slightly harder steel, a smaller file leaves a sharper cutter with more hook so it cuts faster and the better steel keeps it sharp as long as others
Loony661
462’s 4-LIFE
2:40 AM
Winona County, MN
13/64 is also made to fit STIHL’s 2n1 sharpener system holding the file a little higher on the tooth.. FWIW, I’ve always used 7/32 on all 3/8 chains, including STIHL.
Skiptooth Fred
5:40 PM
What about using 13/34 on X cut?
Use it if you need to, when hand filing you can file accordingly. 7/32 is the preferred size and I finish when the tooth is getting small with a 3/16. Just file it to keep the hook. It’s not bad chain but remember after the first filing you loose the xcut shape which is kinda between square and round. File it use it 👍
WI_Hedgehog
2:40 AM
Milwaukee, Wisconsin, U.S.A.
On the back of the box it says 7/32" file, 30° swing, 0° tilt: that files a tooth in one operation, but it's not how the chain comes.
If you use a 5/32" file and do two operations per cutter the chain can be made "near new."
beaglebriar
The Peanut Gallery
3:40 AM
Warren Center, PA
I file my stuff with 7/32 and they cut better than out of the box. Just finished touching one up a few minutes ago...
X cut is pretty hard and will dull a file rather quickly.
WI_Hedgehog
2:40 AM
Right now I'm using Husqvarna, they're working pretty good. Also have save edge and pferd no real preference of one over the other.
@julie wolf and I both used PFERD Classic Chainsaw Files, no issues, though she was only taking 1 to 3 strokes off the very tip of the top-plate, and I'm guessing 1-2 off the side plates. I got into a mess and took 15-20 strokes off some chains, the metal bits were piling up, she was laughing...
I hear Vallorbe is awesome, just couldn't get my hands on any thanks to the gov't shutdown and supply line shortages (or something).
Squareground3691
3:40 AM
New England
RCBS
Redneck Savant Extraordinaire
3:40 AM
Ohio - The hilly part
I tried 13/64 on Oregon chain and didn't see any significant difference in ease of sharpening, cutting speed or edge longevity. I should note that I am not a 'great' filer nor do I make my living from my saws. Pferd has 13/64.
