- 12:00 AM
- Jan 24, 2018
- Extreme Southeast CA
My son is rebuilding and shift kitting his 47re. I’ve never done an auto. Got him the ATS manual. Any other pointers?
That picture was taken 3 or 4 years ago. It ain't so pretty anymore.Looks like a pretty fresh mill too. I dig it
Only 351 W I got to play with was in my gramps 76 f350, also with a t-19. Had a propane conversion so paying like $0.80 cents a gallon was cool
My 2001 Ram has about 190,000 miles...it received its 3rd transmission about 185,000...If I had to do it over id probably swapped to a NV5600 manual at 1000,000 when the first transmission went.My son is rebuilding and shift kitting his 47re. I’ve never done an auto. Got him the ATS manual. Any other pointers?
The 47re really needs to be built with desired power output in mind. Up to 350 HP or so they don't require much compared to 500+ as far as billet shafts, flex plate and torque converter. Either way hydraulic pressure needs to increased so it can take advantage of of the Cummins outstanding low end torque.
I hate the 47RE almost as much as I love the 5.9 Cummins.
They can be made run and shift well though.
I'm no expert. He should read as much as he can on the Cummins forums.
That's the important part....even if it sounds and shifts like a dump truck...I bought my truck with a double disk clutch and nv5600. It’s bullet proof but the clutch is loud as hell and the syncronizers take a long time to line up the low gears. Nothing’s perfect I guess.
You really need to get that back.His was a freshish rebuild based on what we found. Clean inside, couple messed up clutches. Inexpensive aftermarket TC. Gave it a new decent triple disc, clutches/wear parts and shift kit. Main problem wasn’t the trans, it was that the flex plate to TC bolts backed out and ground into the bellhousing adapter. Figure to check it out and improve while it was out. He’ll at least chip it and do exhaust I’m sure.
My ‘95 was originally an auto dually. Guy I bought it from built it. NV4500 swap. Lots of
Miles and abuse on that truck. I started having shoulder problems and the synchros were going so took it to my buddy for a built auto…4 years ago.![]()
And I thought I was slow.I’ve had a 408 magnum stroker sitting at an engine builders for 7 years I still don’t think is done. So I feel your pain
Dang we have shop like that here,, ya drop it off,, wait 3 months,, then start showing up,,,, thats the only way to get results,, the work done is the best,, I got the shop to do two engines and tons of heads,,I’ve had a 408 magnum stroker sitting at an engine builders for 7 years I still don’t think is done. So I feel your pain
