2nd Gen Ram Pickups
Woodslasher
Teh debil
6:20 PM
Commiefornia
I wonder if anything would show up on a scan? Even a communication error could be a clue.
The scanner I borrowed said communication error, failure to connect, or something like that. The new ignition switch didn't help, I chased down all the grounds except for the fuel heater one and cleaned them, no difference. A neighbor has a working but not street safe 98.5 that I can borrow parts from, I'm thinking I'll borrow the I/C and the control module that's near the t-case shifter first.
Hoser
9:20 PM
Grey county Ontario
I’d be curious of the gauge cluster itself, all those feeds to the gauges only have connections, ground and the cluster in common and you’ve narrowed 2/3 out. It’d make sense being the gauges themselves work but there’s a communication error. Granted I say this knowing it’s not my time, hands or patience changing it out and I’m not well versed on a 24v, 12v and gasser I’m alright
Woodslasher
Teh debil
6:20 PM
Commiefornia
The plot thickens! I went to move the truck tonight but the battery vampire had struck! Or, in plain english, the batteries are dead. So, now I get to hunt down a major power draw. Now when I got the truck it would suck used batteries dry while it was just idling but once I put a new set of batteries and cables in it that issue was cured, or so I thought.....
Woodslasher
Teh debil
6:20 PM
Commiefornia
Now I’m afraid for Ben’s 24v
Nah, I just went through this with a neighbor. My truck sat for 13 years in the brush and was ridden very hard and put up wet, which is no bueno. If the truck was maintained or regularly used until you got it it'll be fine-er. Sitting for a decade kills stuff just from lack of use. Moisture collects on chit, corrosion forms, petroleum products gel, etc, and then when you go to resurrect it you have wiring gremlins, chunks of chit blocking passages/lines/ports, etc. The quarry my truck briefly stayed at had an 2000-ish 1500 and a 99 2500 24V still in daily-ish service with no issues to speak of because they'd been in continual use for 20 years.
Loony661
462’s 4-LIFE
8:20 PM
Winona County, MN
Exactly. Which reminds me - check the 3 large plug-ins where the wiring harness connects to the PCM on the firewall. Be very careful but check to see if the pins are corroding. That may be your issue. And sometime just a squirt of Fluid Film, or some Die-Electric grease, will help it make contact again. Also, check for any broken pins…
maulhead
7:20 PM
Home
maulhead
7:20 PM
Home
1998.5-99's are kinda known for electracal gremlins.
They made a bunch of changes in 2000, then more in mid year 2001, which seemed to help.
maulhead
7:20 PM
Home
That looks very nice. My 99 has the infamous clear coat peeling issue.. sooner or later I’ll have it painted. Sometimes I want to do a single color, and other times I want to do a 2-tone with the second color placed in the middle of the body, not just the bottom.
I always liked, waterfall two tone. It was only a 3500 thing thou, and they discontinued it in 1998.
I was bummed the night I ordered my 1999 3500, and found that out.
I had my heart set on a waterfall red & black 3500.
Loony661
462’s 4-LIFE
8:20 PM
Winona County, MN
I like the waterfall, but not the lower break style.. And I’ve always like center band, that’s just classic.
maulhead
7:20 PM
Home
IIRC only first year had metal mirrors.
1994-1997 had the chrome mirrors.
1998 they started using the black ones (like pictured below) they changed the shape a bit also, more oval / rounded edges, not as square.
2000 is when they came out with the flip up, tow mirrors that everyone makes memes about.
They also changed the body molding in 1998.
1994-1997 had a chrome strip in the body molding,
1998-2002 they ditched the chrome strip, and changed the shape a bit.
I used to really geek out on 2nd gen trucks, and paid attention to all the little changes. Now all this useless info is stuck in my brain forever.
Every 2-3 years they were changing up the colors also, adding new ones, dropping old ones. I'd need to dig out a big salesman book I was given, pretty sure that color (on the truck above) was only a 1996-97 color, if my memory is right.
Woodslasher
Teh debil
6:20 PM
Commiefornia
Checked the plugs, no corrosion or loose wires I noticed and the fuel pump relays I was advised to check were a-ok. No drain on the system tonight when I checked it, but the batteries were at 9 volts and a few hours on the charger brought 1 from 9.76v and 43cca to 12.13v and 314cca. That ain't the 840cca it's supposed to have. So, I'll pick up a new set of batteries tomorrow and try again.
Hoser
9:20 PM
Grey county Ontario
I have chrome 4 point mirrors on my 95 cab and chassis. Would this be factory? I’ve seen them on a couple one ton second gens
  • Like
Reactions: Lnk
