2nd Gen Ram Pickups
Kiwioilboiler
346 Pic Examiner
1:46 AM
Marsden Pt, NZ
While performing the spring install, I ran into some trouble with the Track Bar hardware. I got by for a week or so, but today I had to replace it, as it was backing out. The threads were damaged when installed the bolt last time, and the nut didn’t hold..
Here’s the new hardware, metric of course.
And in the process of removing the track bar, the castle nut that holds the ball joint in the frame side, stripped out. So I ended up making my own castle nut after trying several auto, implement, and hardware stores looking for a 14mm X 1.50 size.
Took longer than I wanted to repair, but it’s done right and I shouldn’t have to worry about this for a long time.
Commie.
Loony661
462’s 4-LIFE
8:46 AM
Winona County, MN
I’m starting to get frustrated with the aging plastic dash in my pickup. It’s slowly falling apart - and I mean underneath and behind the main pieces. Granted, my truck drives over rough terrain nearly 1/2 the time. I don’t know what I’m going to do to save it..
redline4
I'm huge in Japan
8:46 AM
Rosholt Wisconsin
Gorilla glue and indoor/outdoor carpet.
Your welcome.
mainer_in_ak
5:46 AM
Interior Alaska
I repaired one with very thin remnants fiberglass and epoxy resin. Roughed it up, primed it and shot a few coats of UPOL raptor with my shutz gun. Color-matched the factory color as best i could.
On the tintable raptor, a napa paint department can help color match and sells certain paint in small batches. Make sure no binder is added to the automotive paint. The raptor cured better.
U could also wig the fk out while driving and then get a dash skin. Doesn't help the lower exploding dodge interior parts though:
Loony661
462’s 4-LIFE
8:46 AM
Winona County, MN
So to be clear, I have already invested in, and replaced the main top dash piece that is known to crack and bust up. When I replaced that, is how I saw some of the damage underneath.
The top piece took me 14 hours to replace over a weekend with how bad everything was getting (I also did a heater core while it was apart).
Loony661
462’s 4-LIFE
8:46 AM
Winona County, MN
Your welcome.
On the larger pieces this could work, but it’s failing on the smaller structural pieces underneath everything. Also some of the tabs that hold the larger pieces are just breaking off.
redline4
I'm huge in Japan
8:46 AM
Rosholt Wisconsin
Ok then.
Great stuff expandable foam, gorilla glue and indoor/outdoor carpet.
redneckhillbilly
7:46 AM
NW MT
whats a common cause of a cummins dieing when put in gear.
94 12 valve, auto trans.
pampered truck with less than 100k on the clock, when you drop it in gear it dies, and when you come to a stop it will sometimes die.
i am thinkg torque converter is not unlocking, but I could be way off base, customer called to ask about turning up the idle, but I think thats a rig job and would rather fix it properly, could fuel pressure cause a symptom like that? anyone else experienced this before?
davidwyby
Rural desert logging
6:46 AM
Extreme Southeast CA
Been thru it, can’t remember 🤦🏻‍♂️😆
davidwyby
6:46 AM
How does Ac Compressor affect it?
What is the idle rpm in neutral ?
redneckhillbilly
7:46 AM
NW MT
I will have more specifics later today or possibly tomorrow, I have not looked at it in person yet, was just curious if anyone had delt with this symptom before and what they came up with.
Loony661
462’s 4-LIFE
8:46 AM
Winona County, MN
I’d be checking the basics first like fuel filter, etc..
