272xp Rebuild and Port
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
Did you degree the ports before you tore it down? I find it helpful in analyzing what I want to change. If you intend to delete the gasket then raise everything back to where it was having the pre-tear down numbers help with that plan too.
I did degree it before, I'm going to degree it again when I get the new bearings in it and the new piston installed. Those two things alone could cause some changes.
XP_Slinger
They’re Just Saws
1:54 PM
Central NY
Yes they could. Good stuff, I'm still learning also. Looking forward to how this one turns out:)
calebng15
1:54 PM
Butte, MT
Split my case, and got the bearings off. I don't have the bearings yet, so I'll put them back on later.
Couple pics of my splitter. I should have used stronger metal, I probably wouldn't have had to ad bracing.
Not pretty, I know! But it works! Here it is on the case.
Gets the job done!
calebng15
1:54 PM
Butte, MT
Looks like it might need them?
I'll use this puller for the bearings. I need to get me one. This is my dad's. It's a little big, but it has to be this long, so...
Takes 'em right off!
Probably time for a new bearing!
Have a little clean up on the cylinder, but really isn't that bad. I would have thought it would have been worse. But then again what do I know! I don't know why, but splitting a crankcase is my favorite part of a rebuild like this. Maybe because the case is pretty well clean, and I can just take my time?
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
Yikes, your bearings were in real bad shape. Mine were still complete but rough.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:54 PM
Provencal, Louisiana
Dang!! Wheres the rest of them?
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
Hoping to put my cases back together tonight. What's the opinion on the case gasket as far as sealer or no sealer ?
Motorhead
Cantre Member
1:54 PM
Tampa Fla.
Just my .02 cents,If the gasket is of a good quality,Ample thickness,I clean up the mating surfaces,use the good gasket no sealer,If the gasket looks a bit cheap,Thin,I use sealer.Its much easier to put them together with a good quality gasket and no sealer.
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
Got this new toy, er I mean tool today. Ended up with about $20 in it all. Way more accurate than my old paper print out/magnet wheel.
Couple seconds with a unibit to open the wheel to 1/2" and bam.
No saws will be safe from my port timing curiosity.......
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
Well that was easy enough, made a rookie mistake and didn't have the rod in the right spot when I dropped the crank in the case. Luckily I had it warm enough to tap the crank and bearings back out and drop it in again.
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
I put the top end back on to check squish and timing numbers. Squish was a little tight and inconsistent because of some carbon build up in the chamber. So I used the old piston with some self adhesive 3M sand paper to clean the carbon out and take a few more thousands to put squish at .020 without a gasket.
Magic_Man
Oh Yea !
1:54 PM
SE Ohio
Alright, now is where I need input from you good fellas that replied to my other thread about building this saw. Everybody wanted to see what timing numbers where as stock and here is what I came up with.
Ex: 106
Trans: 128
In: 73
Port widths:
Intake 33mm = 63.46%
Exhaust 30.5mm = 58.65%
Piston Skirt width = 41.25mm
So whatcha think about those @Mastermind @jmssaws @David Young @rattler ? Or anybody else who has some input on timing numbers for a 272xp.
This saw will be run by my old man wearing a 24" bar and Stihl RS chain. If we bleed off a little compression to help with starting that's ok as long as we don't loose too much torque.
