254xpg cosmetic resto
dustinwilt68
Wilt Built Work Saws
10:47 PM
Southwest PA
I have 1 288 that is perfect except the cases, but I probably won't ever restore that 1, I have another perfect 1 and if in paint it I won't use it.
Drptrch
Coastal Fartknocker
10:47 PM
Petaluma, California
Ah now ya guys started something ....[emoji848][emoji847][emoji847]
2100CD thin ring
Having a little slow down with flywheel removal and no tool
XP_Slinger
They’re Just Saws
10:47 PM
Central NY
2100CD thin ring
Glad you've caught the rebuild bug. I think a lot of us enjoy these simple rebuild/resto threads. I for one enjoy the mental break from thinking about porting theory.
CJ Brown
I learned it from a hockey card...
10:47 PM
Belleville, Ontario, Canada
2100CD thin ring
Throw the whole assembly in the freezer overnight. Next day, heat up the case with a torch or heat gun (avoiding the crank/bearing) and the crank and bearing should slip out with the tap of a (rubber) hammer. Don't concentrate the heat strictly around the bearing recess - spread the heat to the surrounding areas of the case as well.
Drptrch
Coastal Fartknocker
10:47 PM
Flywheel is still attached to crank on that 1/2, trying to get that off, truer tapping crank end with punch to vibrate, and stud with nut protecting end of crank. No luck
CJ Brown
10:47 PM
You could try the same process - put it in the freezer, then when cold, heat the flywheel, apply slight prying pressure with a screwdriver between the case and flywheel, and a sharp rap on the end of the crank to pop the flywheel off.
dustinwilt68
10:47 PM
Southwest PA
Hold the flywheel with a pair of pliers up off of your bench, and leave the nut on the crank and bump it, usually works for me.
Drptrch
Coastal Fartknocker
10:47 PM
Painting question:
Obviously clean surfaces
Paint dry paint ?
Paint dry sand paint ?
Primer dry paint dry paint ?
Primer sand paint sand paint?
Thx. ( probably like a which oil is best question [emoji13])
Any diff steps between Mag and plastics ?
