10mm 044 build/port
Adirondackstihl
3:18 AM
Upstate NY
If that meteor box is for this saw ,i think the pin bearing spacing on those is the width of a 12mm saw ,and when use on a 10 mm rod the pin bearing can walk out more than it should .Jeremy did a thread on them once .
Yes
Chris and I were in direct contact with Antonio from Meteor Italy.
Adirondackstihl
3:18 AM
Upstate NY
Not sure if helps power or not ,but the oem has larger widows in the piston .
Yes
The OEM 10mm has much larger windows.
Before I noticed the pin boss discrepancy, I was opening the windows on the Meteors to match the OEM on all the 10's I built
CR500
3:18 AM
Western NY
You talk to yourself Jason? Or are you not that lonely yet?
Sent from my non internal combustion device.
cgraham1
12:18 AM
Nor Cal
The saw was completely disassembled and dirty, plus some parts may have been missing... :eusa_whistle:
malk315
Running Saws for Therapy
3:18 AM
Lancaster, MA
I heard a dual port muffler and an hd2 filter wakes these saws up .:D
Hi Mike ;)
I put @Canadian farm boy maxflow filter on mine and it woke it up even further beyond the HD2 w/ DP Huztl muffler.
It really is amazing what just the HD-2 + DP muffler does for these. I had the 10mm at the GTG and @huskyboy had the 12mm at the GTG. Both saws in mint condition.
If I can turn the one I brought to the GTG into my saw (it's a friend of a friend's) I would like to send it to Jason for some love.
