Willard
- 7:35 AM
- Apr 13, 2017
- Manitoba
Found my notes.Thanks for the info Willard, she’s got the metal flywheel, short cases and small end crank stub if that’s any help too
• Mid 1994 after ser. # 129588002 beefed up crank big end changed from 12 to 13 roller bearings.
•Early 1996 after # 131917066 new poly flywheel and mag side crank bearing increased from 13.5mm to 15.4mm.
•Mid 1996 after #131960509 decompression valve installed on all 066.
•1997 after #143459523 first top cover plastic 066 badge.
So appears you may have a 1995, maybe 1994 with 1996 cylinder upgrade.
Check your serial #.
