- 11:37 AM
- Jan 12, 2016
- Iowa City
Have you tried any of the uni with the rubber base?
Yes, that is the one I'm using. Part number UP-4200ST.
What is this eliminator adapter you speak of?The standard 288 filter neck sits at quite an angle. I measured it once and iirc it was almost an half inch from front to back.
This is how the eliminator adapter worked!View attachment 36242 View attachment 36243
Rite on. How do you like this compared to the green weenie for these?Yes, that is the one I'm using. Part number UP-4200ST.
The eliminator was an aftermarket kit. I believe Husqvarna bought the patent or rights from them for there high tops. @jacob j. or @Eccentric should would have more info about them. I believe that they also had the kits for 61/66/266/268 and 272.
Here was my 181 thin ring with the blue top cover "eliminator kit" and my 288.View attachment 36262
Better get that tygon impulse switched out. I used it on the 7900 and it melted off in the middle of millingView attachment 36224
Not much room in here. So, would a 288 elbow fit and give me more height to put the stack on?
@mdavlee
It was all I had that fit. I do have better thick fuel line now.Better get that tygon impulse switched out. I used it on the 7900 and it melted off in the middle of milling
That's what I did too. I figured it'd be fineIt was all I had that fit. I do have better thick fuel line now.
This saw probly won't make much more than 3-5 cuts at a time anywayBetter get that tygon impulse switched out. I used it on the 7900 and it melted off in the middle of milling
You sell all those filters??View attachment 36045
7 of the different models we have tested from unifilter
I will say it is nice to be able to go into any motorcycle specialty store and buy K&N, Unifilter and a bunch of different filter options, as well as oil and cleaner.
We sell four different models with the stacks, the others I picked up for testing.You sell all those filters??
Sent from my SM-G900R4 using Tapatalk
Well, what's the verdict? I want one for my Solo...View attachment 36224
