stihl livin
Do the Dallas
- 6:38 AM
- Dec 4, 2015
- At the farm
I believe it’s in this thread in some of the early pages.
Thanks guys! I have the saw up at our cabin, the next time I'm up there I'll check that pin out. I thought I remember reading something about it but was under the impression that it had to be pushed in in order to adjust the oil flow screw, and mine does turn back and forth. Dan, I take it that the pin in your picture has been pushed down already, it looks pretty flush? Hopefully that's all I need to do.
Pete
I was thinking about what that bloke in the vid said about the amount of fuel used 100L
Over 3 months when we get busy around here we use that in 2 weeks .
Geez bust my balls. I’ve cut with it like this. It oiled fine. I’d pick something different if I used it everyday.The cardboard test isn’t really definitive. I could put a 36” on a 026 and piss rev oil on the cardboard. What matters is the output under load in the wood and if the chain appears dry after numerous cuts. But yes, a 462 does have a good oiler output with the pin in.
i need to come cutting with you again soon me thinks!I’m using between 6 to 8 ltrs a day at the moment
in about 5 weeks time i have a weekend free shall be in contact.Anytime champ
I have hundreds and hundreds on mtrs to block up
@AlfA01 have you had the running in reverse condition happen again? Or has it been behaving?
