Looking good
So bar change made difference?
Were those saws cold?
The question for me is.....If Stihl have a form of "Air Injection" or "Centrifugal forced Air induction " (depending in the patents and terms ) on the 462 and decided not go with it on the 500i ...how come and why not.
It’s a very simple answer.No. I'm thinking the flushing and running diesel/bar oil mix helped. I still don't think it would oil a 36, but 24-25 it's doing fine now.
First vid with the saw...20ES Light....second vids...28 Tsumura...finished cutting yesterday with a 24" Tsumura...3rd vid 25" ES Light.
As in first start of the day? No.
Good question and not one I can answer...
If you gonna be around Athens after Wed i can give you a 36 to test.
I ll be cutting some trees at Monday so...
Me ether ...it seems odd not to "if " the outcome is an improvement over not using it. The flywheel situation on the 500i is nothing like the norm so maybe that and the case come into the thinking. The designers will have gone through much to get to this design after all.No. I'm thinking the flushing and running diesel/bar oil mix helped. I still don't think it would oil a 36, but 24-25 it's doing fine now.
I think the MS500i needs all the air for the cooling.
This saw gets real hot because everything is extrem tight.
The cooling air stream on the clutch side is extrem, just like a fan.
, I am gonna agree with @Wilhelm, give me the 2x 7910 or 2x 681. This Xtreme heat of the saw Dan talks about I think could end up being a very big issue, thanks for taking the time Dan and doing this. You don't happen to have a stock 281 would you?
That makes sense, as one of the first things I noticed was the heat from the cylinder cover.
In some German videos the 500i seems to be running more like a 572xp, but we know nothing about the chain, wood and so on.It seems that you made the saw running a little better with your oiling system work Dan but i believe that something is off with your saw.Either you have a lighting fast Dolmar or the MS500i you have is defective(don't oil enough problem or something similar,i am not sure).There is another thread here for the MS500i and Steph compares the 500i (ammong some other saws) with a 7910.In his videos,the 500i seems quite ahead of the 7910,kinda like the dolmar is less cc's.In your videos the dolmar is ahead of the 500i with some distance.
Since the fuel gets injected I would guess the engine runs on a much leaner mix than a carburetor fed power head.I can see how the specific cooling needs could figure in the mix. That in its self brings up another facet to the hole design discussion ...what makes this saw run so hot . Its still a cylinder in a plastic cover on a mag case after all , just like any other. Fuel injection being the major change ,but why would/could that give this motor a hot running issue to be factored in ?
I think that is how they sound, in every video I've seen that is how they sound to me. Sound can be very deceiving IMHO, and doesn't necessarily mean the saw is gutless.I am far far from expert but Dan's saw seem (sound) gutless in the last video.I know this type of wood is very difficult because of the resin and the density of the wood but the saw sounds really sad.
Perception can be VERY deceiving!I think that is how they sound, in every video I've seen that is how they sound to me. Sound can be very deceiving IMHO, and doesn't necessarily mean the saw is gutless.
