CLEARCUT
- 10:47 AM
- May 14, 2019
- Oregon
Yeah, I try to just do my corners and where my wedges might be. And backbar it when I can. The worst is when the wind is just swirling that crap all around you and it doesn’t blow away.Is that right eh? You should send that picture to a rep and they may work on a better filter because that is a ton of dust. It is good you guys got that sock on. Good call.
I try minimise bark shaving.I r is time consuming. Sometimes just the corners and the back for wedges.
Ring the bark on the back bar. See how he is doing the undercut in the picture? He either cut the bark and flipped the saw or once you cut most of the bark then tip cut up to your close corner then bore in and cut down. Just like I would do on usually odd shape cedars because these is nothing to dog into on the high side.
